Used G35(2006) - noise coming during initial acceleration
Old May 30, 2010 | 01:37 PM
g35_ifty's Avatar
Hello,
I recently joined the Infinity club after buying a G35 auto trans sedan ...
I found this forum on google with some good information on maintaining the Infiniti machine...
I don't know if any of you are familiar with the below issue...
Yesterday, I noticed a noise coming out from front side of the car. This kind of noise is only coming up every time when I drive a very small distance (<0.1mi) from the parking position. Later on, there is no problem.
Its like a clanking or a bit grinding kind of noise...Did anyone of you experience it?
Kindly help this new Infiniti driver with your inputs...Have a good weekend guys..
Thanks,
Kris
Old May 30, 2010 | 02:05 PM
itgogitrev's Avatar
Sounds like ABS test, I think it kicks in around 9 MPH and only does once per startup.
It's normal.
Old May 30, 2010 | 02:15 PM
Mustang5L5's Avatar
Sounds like abs test to me too. It's normal.
Old May 30, 2010 | 02:51 PM
codeflux's Avatar
agreed with others, ABS test, normal, chill and enjoy your ride!
Old May 30, 2010 | 03:24 PM
s0nicstr1fe's Avatar
is it more of a metal CLANK sound?
Cause the ABS test sounds more like the car farting to me thank a clanking sound.
Old May 30, 2010 | 04:27 PM
5150DS's Avatar
It sounds like those spring door stops when you bend them back and let them go.
Old May 30, 2010 | 06:26 PM
Mustang5L5's Avatar
If you time it right and hit the brakes when the abs test activates....you feel and hear a loud buzzing in the pedal like an abs stop.
Old May 30, 2010 | 11:04 PM
tgeml's Avatar
I own a 2006 G35 sedan with 55k on it, and I can reproduce what you're hearing, It's definately an ABS test as it sounds EXACTLY like what happens when you start slipping on snow and the ABS goes all out(yay michigan!). I wouldn't worry if it sounds like that, now if its a tinny noise, or a clicking noise, id stop by the dealer, most of the time they're helpful and don't charge for little things(Infiniti of Troy ROCKS).
Old May 31, 2010 | 06:41 AM
Blue Dream's Avatar
I drove ttrank's car solo
Good job guys. My car sounds like it's running over a grate complete with vibration and everything.
It's definitely normal and a good thing to hear. If I ever don't hear it I'll start to worry.
Old May 31, 2010 | 04:25 PM
ThePhoenix's Avatar
yea ABS check, freaked me out first time also lol, mine kicks in when coming from cold and the noise/check occurs at 1900 RPM just before shifting into 2nd
Old May 31, 2010 | 07:48 PM
g35_ifty's Avatar
noise
Thanks all for your inputs....it really relieved my fear that I overlooked this noise while buying it ...
Yes yes, it sounded like a spring door stops bent and let them go...
I will follow your advise and continue driving it...
Its wonderful to have such a G35 community
thanks again...
Regards,
Kris
Old Jun 1, 2010 | 12:44 PM
itgogitrev's Avatar
One thing that I've noticed is that the noise get a little more prominent when the pads get a little thinner. I almost don't even notice it with new pads.
Old Mar 14, 2011 | 02:51 PM
SMartinG35's Avatar
I have the same noise from my 06 G35 Sedan. I purchased my car used and when I heard this noise it freaked me out as well. The dealership did say there was a fix for this, but told me it really isn't worth paying for it because its a normal thing the car does.
Old Mar 14, 2011 | 04:15 PM
Blue Dream's Avatar
I wonder what the "fix" is. I kinda like knowing my ABS checks itself every time I start the car.
Old Mar 14, 2011 | 05:20 PM
thescreensavers's Avatar
Mr.202?
Is this what you are hearing?
