wheels spacers question
Old Jun 11, 2010 | 05:17 PM
SN00P's Avatar
CLUB MODERATOR
im getting some 15mm spacers for my car just for the front and found out that if your wheels on the back don't have a shaved slot for the stock studs you can NOT use the ichiba V2's i would have to get the V1's
my question is are there any other spacers out there that if i do get a style where they directly fit over my stock studs that i can get ???
here is some pics of what im talking about .. yes i no that isn't a g wheel its an example
i want something like this where the studs are flush with the spacer
Old Jun 11, 2010 | 05:37 PM
G35Papa's Avatar
It depends on what size spacers you are going to get and whether the spacer itself is thick enough to cover the OEM studs.
If the back of your wheel doesn't have the holes to go over the OEM studs going beyond the wheel, you can cut the OEM studs to they are flush with the spacer.
Old Jun 11, 2010 | 05:39 PM
SN00P's Avatar
CLUB MODERATOR
would a 15mm work to cover the studs or no ?
Old Jun 11, 2010 | 05:47 PM
G SEDAN's Avatar
what size spacers are you getting?
G SEDAN's Avatar
no, you'll need the extended studs
Old Jun 11, 2010 | 05:53 PM
LightsOut's Avatar
SIETESG
the thing is.. have you checked your wheels, if they are flush or not?
Old Jun 11, 2010 | 06:02 PM
SN00P's Avatar
CLUB MODERATOR
yes i have checked my wheels and know for a fact they are flush in the back .. im just going to order some V1s then and take what a hr out of my day and put the new studs in ..
Old Jun 11, 2010 | 08:49 PM
CG4DR's Avatar
just lower it more and get a camber kit lol
Old Jun 12, 2010 | 11:36 AM
AARONHL's Avatar
Does everyone run into this problem with V2s?
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
