AC Condensor has a hole! Ahhh...
Old Jun 13, 2010 | 12:41 AM
Idyfohu's Avatar
Angry AC Condensor has a hole! Ahhh...
I took my car into Goodyear today hoping that I had a small leak since my AC isn't working (temperature is getting up there unfortunately as well). After putting in dye they said that I have a good sized hole in my AC Condenser and their cost was $150 for the unit and another $200+ for the installation...I opted to leave (after paying $45 for the stupid test) and am now hoping someone has had some experience with this. I'm curious where I might be able to find an AC Condenser (probably call Autozone, Checker, NAPA, etc. tomorrow) and if anyone has installed one of if you've seen any DIYs on the installation.
Thanks!
Old Jun 13, 2010 | 12:54 AM
jibberjabbers's Avatar
Common problem, the intake will rub a hole into the AC lines. Need to find a way to protect the AC line, Maybe putting some silicone hose covering for the lines near the intake.
Not sure about the DIY...
Old Jun 13, 2010 | 01:37 AM
Tollboothwilley's Avatar
Hole in the AC Condenser, not the AC lines.
check out www.infinitipartsonline.com
or call Riverside Infiniti and ask for RICK
they generally have the best prices you can find between those 2 places
Old Jun 13, 2010 | 09:32 AM
Mustang5L5's Avatar
You can prob install the condenser yourself, but refilling the ac is something you need special tools for.
You must pull a vacuum on the system using a pump capable of very high vacuum, and then you refill with oil and r134 based on system pressures using special gauges.
But another good source of a condenser might be rockauto.com.
Old Jun 13, 2010 | 10:40 AM
5150DS's Avatar
^ Rock auto is $108 and after shipping wouldn't be much of a difference.
Old Jun 14, 2010 | 01:48 AM
Idyfohu's Avatar
Thanks guys for the awesome links and info...any of you guys ever attempted to install? I'm ok with car stuff (done countless suspension and random things (most difficult being Plenum)) but this looks a bit more involved.
Also, vacuuming and replacing will be $75ish assuming I can install the stupid condenser...sucks so bad!
Old Jun 14, 2010 | 06:49 PM
Mustang5L5's Avatar
It's not that bad. I'll have to take a look at my condenser to see how bad it is, I think all you'll need is basic hand tools and some ac spring lock tools and you can do it
Old Oct 10, 2011 | 03:23 PM
Gshroom's Avatar
can someone show me in a picture where and what the ac condensor look like?
Old Oct 10, 2011 | 03:40 PM
Mustang5L5's Avatar
Small radiator in fromt pf the engine coolant radiator
Old Oct 13, 2011 | 04:44 PM
Gshroom's Avatar
thanks... I just found out that the reason why my AC stop working is cause my compressor clutch broke.
Old Oct 13, 2011 | 04:45 PM
Gshroom's Avatar
just a warning to everyone.. check your AC compressor bolt.. cause if it falls off like mine its gonna cost ALOT of money to fix
tkuntz
20 Inch
21
Sep 26, 2016 09:13 AM
G35xdriver04
Nov 7, 2015 08:31 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
AesonVirus
Engine - Exhaust
Sep 20, 2015 01:54 PM
JustinMKN1
Sep 18, 2015 03:40 PM
