service engine soon light...help!!
Old Jun 13, 2010 | 01:07 PM
oscar_g-sedan06's Avatar
Originally Posted by tonke73
I've never heard of any SES lights being triggered by having low fluids. If it happens again, go to autozone and have the codes read by an ODBII reader like someone said earlier.
thankx hopefully dnt come out again
Old Jun 13, 2010 | 01:36 PM
Mustang5L5's Avatar
Ses light is usually triggered by faulty engine sensors, emissions codes and sometimes transmission faults.
Old Jun 13, 2010 | 04:12 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by oscar_g-sedan06
i would do thanx for the advise... im going to take off in a bit just checked water its good oil missing about half a quart stop by auto zone and buy a quart and put half...hopefully stays off..if it doesnt turn back on u think i should still worry?
Your oil may not have been low at all... how long did it sit? The VQ takes a ridiculous amount of time for all the oil to drain down and get a accurate reading. (At least 30 mins, sometimes more)
You just need to get the codes read and report back.
It's funny to me how some cars will set the SES for anything...
The 96 suburban goes from no light at all, to light, no light, blinking, light, no light... and always runs the same... it's been doing it for months. I have the software and cable to read all the codes and sensor data and I'm still to lazy to check it out
Old Jun 13, 2010 | 04:46 PM
Choleaoum's Avatar
I recently changed my oil after recieving a SES light for overheating (my fan shroud jammed the fan which made it overheat) I reseted the light, changed my oil and only about 2 liters came out which was crazy lol. I haven't changed my oil in about a year mainly because I only put less than 10k miles on the car. Anyways, I changed it only 2 liters came out but I did get the oil light at heavy breaking which was caused by the oil tipping and the sensor etc etc. So it really does take a lot for the VQ to realize there is no oil lol. My dipstick wasn't accurate at all, which is another reason why I never changed the oil.
I don't think it was that serious for him if he turned off the car and the light went away.
Old Jun 13, 2010 | 05:04 PM
NFSP G35's Avatar
? = 2B || !2B
^Which is just one of the reasons my G gets an oil change ever 3-4000 mi.
Old Jun 13, 2010 | 11:57 PM
so just got home the ses light didnt come on till around 4 today as soon as came on headed to autozone guy told me that they dont do the code reader since 1 year ago so i headed to pepboys and were charging me $89 + tax so when i left turned on the car and light was off again bt i notice that it happens when engine gets really hot could it be overheating???bt gauge shows it normal..should i take it to the dealer dont have warrenty anymore??any advice im off tommorow anything i should check???
Old Jun 14, 2010 | 11:18 AM
NFSP G35's Avatar
? = 2B || !2B
Try Advanced Auto, I've never had them try and charge or say they don't do it... but I have been there when they're reader was broken or the guy didn't know what he was doing
Old Jun 14, 2010 | 01:37 PM
ALRITE WENT TO A LOCAL MECHANIC AND DID THE CODE READER AT NO CHARGE AND CAME OUT TO BE HIGH RPM'S BECAUSE OF MAF..K&N FILTER OIL GOT IT SUPER DIRTY SO GOT IT CLEANED WITH MAF CLEANER NOW SES LIGHT OFF AND NO CODES ON READER...
Old Jun 14, 2010 | 03:01 PM
Eric@TCGMiami's Avatar
damn, and it wasn't acting up?
When a maf throws a code it usually has fluttering since it cant really detect how much air is going in the engine so it cant calculate how much fuel to compenstate.
Old Jun 14, 2010 | 03:21 PM
well wen i stopped my rpms were between 1 and 2 pretty high and yesterday turned off on me at the stop light
Old Jun 14, 2010 | 03:38 PM
Yeah, MAF would do that.
Old Jun 14, 2010 | 06:52 PM
Mustang5L5's Avatar
Code readers aren't that expensive either. I have an actron 9180 which is a higher level basic reader and it only cost me about $120ish. There are others for 50 or less.
Well worth it if you plan on working on your own car
Old Jun 14, 2010 | 09:33 PM
NFSP G35's Avatar
? = 2B || !2B
I think I only paid like $80 or less for my OBD-II to USB thing, and I can pull codes, sensor values, and even datalog with it.
Old Jun 14, 2010 | 09:59 PM
Mustang5L5's Avatar
Yup. Great tool if you understand how to use it.
Old Jun 14, 2010 | 10:16 PM
  #30
NFSP G35's Avatar
? = 2B || !2B
^I need to get a better one. The one I have only runs a 9600 baud rate, so I can't really get into the advanced stuff like monitoring the CAN bus.
