Oil on PCV valve
Old Jul 17, 2010 | 11:34 AM
jmueller's Avatar
Oil on PCV valve
I swapped out my old PCV valve for a new one, and noticed that there was a significant amount of oil on the old valve. Should this oil be present? It seems a little odd to have oil here.
Old Jul 17, 2010 | 11:55 AM
WhosRich's Avatar
How much is significant? I know you're supposed to lube the o-ring with a little oil.
Old Jul 17, 2010 | 12:13 PM
sloppymax's Avatar
Why would it be odd? That is the crankcase ventilation. If there was a lot of oil then the valve inside may have been seized and was not releasing the oil/vapor back into the manifold. If you want to keep that oil from making it into the manifold then look into one of oil catch cans either as a product or there is a pretty through DYI with parts from home depot here on the site.
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
mbe32
Nov 13, 2015 11:09 PM
BradMD_96
Oct 6, 2015 09:31 AM
