rubbin wheel well
Old Jul 19, 2010 | 09:33 PM
kennymo's Avatar
rubbin wheel well
how do you guys that are slammed avoid rubbing the inside of the wheel wells. im talking about the back tires specifically. im running 275/30/20 20x10 +35 dropped on 350z s-techs and it rubs bad. if i make a turn it rubs. if i punch it it rubs if i hit a bump it rubs. its not the fender lip itself i have clearance there since i cut them. but on the top of the tire its hitting the actual wheel well.
Old Jul 19, 2010 | 09:38 PM
4drmadness's Avatar
well u can either pull ur fender, more negative camber, or put smaller tires..
Old Jul 19, 2010 | 09:56 PM
SN00P's Avatar
CLUB MODERATOR
ill answer this for you since im on 350z tein s techs .... i have a 265/30/19 +25 and about or a little more then -3º ... i as well have cut fenders .... you need some CAMBER
Old Jul 19, 2010 | 09:59 PM
CandlestickPark's Avatar
ill Sedan
+1, either put a 255 on there, pull your fenders a bit or add more camber.
Old Jul 19, 2010 | 10:03 PM
kennymo's Avatar
i have 255s on the way. will a narrower tire help that though? cuz like i said its not rubbing on the part that people normally roll. its the part that like the tread would hit right above the tire.
g35snoop. i have just a little more clearance than you it looks like. kinda hard to tell from pictures but this is mine
Old Jul 19, 2010 | 10:13 PM
SN00P's Avatar
CLUB MODERATOR
yea a 255 will fit in there nice you shouldn't rub anymore ... yea i think I'm a little lower in the rears but you should be fine with smaller tires ... what is your rear camber set at now ??
Old Jul 19, 2010 | 10:15 PM
HaTa's Avatar
More camber, are your shocks soft ?
ill Sedan
What suspension are you running? If coils, what is the dampening set at?
Old Jul 19, 2010 | 10:17 PM
kennymo's Avatar
stock struts with the z s-techs.
camber hasnt been adjusted yet. so its whatever it is at since i put the s-techs on
Old Jul 19, 2010 | 10:29 PM
SN00P's Avatar
CLUB MODERATOR
how long have you had them on your car with the stock struts i always went over a bridge back and forth to and from work and in 4000 miles i blew rear shocks out bad ... i look live a civic bouncing around with cut springs ... lolol ... i cant wait for my BC coils to come in .... if i were you i would have a set of or try and find a set of 350z shocks/struts or up grading to some blues
Old Jul 19, 2010 | 11:12 PM
r1forever80's Avatar
Like everyone said, i think your rear is soft. Im on 255s but on coils and i dont rub. My dampening is set to stiff and im only at -1.9 camber in the rear
Old Jul 19, 2010 | 11:21 PM
kennymo's Avatar
ok i will try and find some new struts from a z or possibly get the dspecs when i can afford them
Old Jul 19, 2010 | 11:58 PM
kennymo's Avatar
do you guys think its worth getting these 350z replacement shocks. its 80 for both rears. these will just be temp. but im not sure if they are going to be strong enough to make it so im not rubbing hella bad
http://kragen.com/productdetail.aspx...artNumber=5795
Old Jul 20, 2010 | 09:40 AM
SN00P's Avatar
CLUB MODERATOR
well if you don't need them then don't use unnecessary money on them ... you can use your rear shocks without a problem but if they blow they blow .. when you drive over bumps and stuff how does it feel in the back is it all over the place , loose , bouncy ... what do you plan of going soon coils ????? if your going to wait a few months then i would recommend getting z shocks to help out a little bit in the mean time to you figure out what your going to do ...
Old Jul 20, 2010 | 01:43 PM
kennymo's Avatar
Yea I will be getting coils. It's just going to be a while. I'm pretty sure the rears are blown right now. It feels like my rear end is going to jump off the ground when I hit a bump
