obd2 code info
Old Aug 7, 2010 | 09:58 PM
canecorso1985's Avatar
obd2 code info
hey im gettin a p0455 code egr gross leak and was wondering if anyone has had this problem so i can fix it myself i was thinkin of doin the pcv ?
Old Aug 7, 2010 | 10:55 PM
Mustang5L5's Avatar
P0455 is "evap system gross leak"
Biggest culprit....the gas cap. Make sure it's tight, clear the codes and see if it pops up again as a pending code on your reader.
I just got this code a few days ago when I left my gas cap loose after filling up.
Old Aug 8, 2010 | 11:44 AM
bigwilly's Avatar
If it isn't the gas cap then its probably the EVAP Canister Vent Control Valve - part# 14935-AM60B. Its a common issue on everything from the Sentra, to the Titan and even the GT-R seems. Seems like all the Nissans are using this crappy valve. I just replaced mine a few months back.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
TurTLe*
Sep 29, 2015 01:43 PM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
