How can you tell if springs came off 6 speed manual sedan
Old Aug 13, 2010 | 09:17 AM
kevintandmd's Avatar
Hi,
I found some stock 2005 sedan springs that I hope to put my 2004 G35x. I would like to find out how can you tell if the springs came off a G35 6 speed with sport suspension? If anyone has a clue to what the difference would be, let me know.
Thanks
Old Aug 13, 2010 | 09:24 AM
itgogitrev's Avatar
There's a series of colored dots painted on the springs. In the stickies above, it explains what colors indicate spring rate, which can be matched to a stock suspension or a sport suspension.
AFAIK, all manuals came with the sport suspension, so all springs with the specific colored dots that match the SS = manual G35.
Old Aug 13, 2010 | 05:29 PM
There are two yellow dots and 1 blue dot. The other one have 2 orange dot.
I can't seem to find any examples on other searches and threads.
Old Aug 13, 2010 | 06:25 PM
brandon1978's Avatar
I sold my original 2006 sedan sport springs (6mt) earlier this year:
Front: 2 orange dots
Rear: 2 yellow, 1 blue dot
Hope this helps.
Attached Thumbnails How can you tell if springs came off 6 speed manual sedan-pict0008sm.jpg
Old Aug 13, 2010 | 06:32 PM
S 854's Avatar
Edit: Ah, post above seems to answer OP's question
I dug up my 06 oem sport springs from my sedan and the dots are:
1 orange dot and 1 green dot (together on same coil)
2 yellow dots (together on same coil) and 1 blue dot (below)
Mine came from a 5AT sport but they have the same springs as the 6MT sports from what I read.
Regardless, OP, if you're going for the sport springs they are stiffer than nonsport so it might be a good idea to upgrade your shocks as well. Why are you only moving to sedan sport springs? coupe/350z springs would give you a 0.5"/1" drop, respectively.
joel extreme
SOCAL Meetings & Events
Jul 27, 2015 11:59 PM
multimut
Canada
Jul 26, 2015 08:43 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
vstypicals
Jul 20, 2015 10:55 PM
Scredeur4
Jul 17, 2015 06:30 AM
