These wheels?
Old Aug 30, 2010 | 10:49 PM
geesteezd's Avatar
niiice i had these on my OB sedan a while back..
Old Aug 30, 2010 | 10:55 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
Originally Posted by toymachine2009
okay just found this broken after taking back tire off. My back tires are warn down so much from being lowered and my car started vibrating really bad. Which i assumed vibrated off a lug nut and driving without a lug nut broke the stud it was on?
Does that sound like the reason it was broken?
now are these easy to fix? Can i just buy one?
ye autozone has them for 2.79 i just replced 3 of them not that hard but be carefull not to mess them up when you put them in ill post some pics in a few
Old Aug 30, 2010 | 11:12 PM
LuXXXz's Avatar
i am looking for those wheels too! they look great on a lowered sedan! im lookin locally, no hurry but i am very interested as well
Old Aug 30, 2010 | 11:16 PM
LuXXXz's Avatar
Okay just found this broken after taking back tire off. My back tires are warn down so much from being lowered and my car started vibrating really bad. Which I assumed vibrated off a lug nut and driving without a lug nut broke the stud it was on?
Now are these easy to fix? Can I just buy one?
im going to check if i can remove one of those of my old hub(since i changed it) its from the front but should prolly be the same length (maybe find out just in case) so ill let you know you can pay for shipping and its yours!
Old Aug 31, 2010 | 12:03 AM
nazc0's Avatar
its 3 bucks at aoutozone no point in waiting for shipping
Old Aug 31, 2010 | 12:10 AM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Now are these easy to fix? Can I just buy one?[/QUOTE]
Yep, they bang out the broken one and put a new lug on. I recommend going OE replacement because my dad's Tahoe had 2 broken lugs and they ended up replacing them with some cheap POS that only threads 1/2 way and the rest gets cut off, needless to say, he wasn't able to put his 20's back one because the threads didnt go out far enough.
Old Aug 31, 2010 | 12:22 AM
G35xChicago's Avatar
good deal!
Old Aug 31, 2010 | 12:25 AM
toymachine2009's Avatar
Cool Just got them and put all 4 on I love the wider tires! What a difference! The rears are 245/45/18 I was running 235/45/18 ! Love these wheels!
Now time for a camber kit so I dont eat these tires in a year!
Old Aug 31, 2010 | 12:30 AM
Originally Posted by 3truman
Nice pickup! Don't you have the 18' sedan sport wheels? What do you plan on doing with them? I might be interested, but I need to sell my other wheels too, I have two sets already. I have black coupe 17's and my stock 17's but I would like a size or two bigger.
Yup selling my OEM sport 18's for 450 to break even with what I just purchased comes with tires on them too, but im sure you will want to switch them out!
here is details on my wheels that im selling and pics of them on and off the car
http://lasvegas.craigslist.org/pts/1928280356.html
Old Aug 31, 2010 | 12:53 AM
CG4DR's Avatar
lol wow.. i'm becoming the official poster car for Z wheels on a sedan..
little blurry but i was at work
Old Aug 31, 2010 | 01:00 AM
nazc0's Avatar
ya the hardest part was waiting for the wd-40 to soak in at there the brakes connect to the car as those screws didn't want to come out you will need a 19mm socket a 14 mm socket and.....a jack to lift your car....and well that's it...and a hammer.....oh also some spacers so that you can put on a lug nut over the new one and start screwing it in and pray that you aligned the grooves right because i didn't align mine right and it slipped off and i had no choice but to break it off again and put in a new one.....wasted a locking lugnut
Old Aug 31, 2010 | 04:24 PM
so since these tires are wider the shop says if they do an alignment there is a good chance that my tires will rub on the fender. So I guess its time to get them rolled. I found a shop that will roll them for 20 dollars a fender. Although they make me sign a waiver incase any paint chips happen..
What do you guys think.. Get them rolled?
Old Aug 31, 2010 | 09:25 PM
3truman's Avatar
updated pics of car with new wheels?????
Old Aug 31, 2010 | 09:38 PM
CG4DR's Avatar
if you aren't that low they won't rub. i barely had to roll mine in the rear and i am dropped quite a bit. and if they make you sign a waver, that just means they are probably going to chip it
Old Aug 31, 2010 | 09:52 PM
  #30
Just ordered my rear camber kit today so I wont have to get new tires once a year.
