Front diff, rear diff and transfer case fluids
Old Aug 31, 2010 | 07:05 PM
jdmfellon's Avatar
Hey guys
Im getting my front and rear diff and transfer case fluids changed tmrw, just wondering should these fluids be synthetic? My mechanic seems to think they are just conventional gear oils not synthetic gear oils.
Old Aug 31, 2010 | 07:29 PM
That1GuyG35's Avatar
I would go with Infiniti/Nissan fluid, if thats not available I would run Motul synthetic gear oil in the correct weight.
Thats what I changed over to when I had my STi, loved the stuff, the transmission just shifted way smoother after. The Subaru AWD system Im sure is way different, some people did a cocktail of different stuff so you might want to just look around a little more.
Old Aug 31, 2010 | 08:02 PM
thescreensavers's Avatar
Mr.202?
I am not sure about the Front diff or the transfer case, but use the search I am sure you can find out what many people are using.
For the Rear Diff, I and many people use AmsOil SVG
Old Aug 31, 2010 | 08:10 PM
nate704's Avatar
Redline!!!
Old Sep 1, 2010 | 05:23 AM
Blue Dream's Avatar
I drove ttrank's car solo
Amsoil Severe Gear is a great choice for the RWD diffs. Not sure about the X though.
Old Sep 1, 2010 | 06:35 AM
Mustang5L5's Avatar
I used mobil 1 synthetic diff fluid for the front and rear diff.
Transfer case is matic d, which I think is conventional aft. I used mobil 1 aft. Transfer case is def not gear fluid don't let him put that in.
Old Sep 1, 2010 | 08:21 AM
StratagemII's Avatar
that would be correct about the transfer case / I use amsoil severe gear for the diffs.
Old Sep 1, 2010 | 10:30 AM
OKStateG35's Avatar
I'm going to use Castrol Syntec 75W90 gear oil for the front and rear differential and Nissan Matic-D for the transfer case.
Old Sep 1, 2010 | 06:54 PM
TurTLe*'s Avatar
its the same diff.
just run what you want/ can get your hands on. I have mobil 1 in the front and rear. And redline d4 in the t-case.
next time around i'm going amsoil because i found a local place that stocks them for cheaper then what i paid for the M1 and redline.
Old Sep 1, 2010 | 07:06 PM
Blue Dream's Avatar
Good to know, thanks^^
Old Sep 2, 2010 | 06:51 AM
TurTLe*'s Avatar
yea only difference might be the mating end to the drive-shaft. but internally same as a 3.5 auto open diff.
Th611
Oct 27, 2015 03:48 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
