for those of you that blacked out window trim...
Old Sep 7, 2010 | 01:47 AM
boostedforlife's Avatar
Did you guys just paint over it?
Did you do a light sand then paint?
Did you sand and primer it?
I was looking for a diy, or to see what others did exactly, couldnt find it. I just saw some people that said they did it, and it looks soooooooooooooooooooooooooo clean
Old Sep 7, 2010 | 02:10 AM
nazc0's Avatar
2006 Vortech supercharged Sedan
how they take it off the car is the main thing i want to know....
Old Sep 7, 2010 | 02:14 AM
socialconflicts's Avatar
not sure how to take it off since i have never looked into doing this.
like anything else, u must sand/prime/paint
Old Sep 7, 2010 | 03:55 AM
Yea I was wondering if they take it off the car or mask the whole car around it....
Yeah standard is to sand prime and paint. But I've seen people get away with super super fine wet sand and just spray over so if they ever want to go back it's easy to take off the new thin layer of paint and buff back it the original layer later.
Old Sep 7, 2010 | 04:55 AM
fais's Avatar
Another option some people here go with is vinyl
http://www.metrodecals.com
I bought black (gloss) vinyl sheet from here, ordered and received it within a week. They also have flat/matte black. Haven't installed it yet but plan to cut out the shape of the trim and install it over the trim. I think it's easier than painting and should be able to be removed down the road if you wish without too much difficulty.
Before this stuff I tried trimbrite blackout tape, it turned out pretty decent but there were some areas where the tape wasn't wide enough to cover the trim with one piece so I had to join two pieces together and that's where it didn't look so good so decided to go the vinyl route. Cutting them out to the exact shape of the trim will be easier too as I won't have to worry about the curves and will just have to cut a little bit extra on each side to tuck underneath the rubber edges.
Also 10% off coupon code from that site: metro10off
Old Sep 7, 2010 | 07:44 AM
4DoorGRider's Avatar
RS Motors Tuned
^ I went with vinyl. Looks really nice. Had a local vinyl shop cover the trim for me.
Old Sep 7, 2010 | 10:30 AM
sofa king's Avatar
^nice!
Old Sep 7, 2010 | 12:21 PM
azt108's Avatar
that looks great! do you have a shot that's further away?
Old Sep 7, 2010 | 02:19 PM
Thanks for the heads up,
which size/ how much did you buy?
and how much left over did you have?
I am trying to see how much I need to buy to I have a little room for mistakes lol but not enuff to do a whole nother car
Old Sep 7, 2010 | 02:21 PM
LightsOut's Avatar
SIETESG
I vinyled mine as well.
My boy did it for 40.00 but avg cost is around 60-80
Old Sep 7, 2010 | 03:37 PM
geesteezd's Avatar
niiiice.. do u know any spots in socal?^^
Old Sep 7, 2010 | 05:23 PM
darnelled's Avatar
The problem with painting is when you try removing the trim peices, the clips that hold them on will easily break and you have to buy a whole new trim peice to replace it.
Old Sep 7, 2010 | 06:03 PM
LightsOut's Avatar
SIETESG
my boy is the owner of Down Shift Graphics.
google it and you'll get his info. He's located in Fontana. I think he raised his rates though...
Old Sep 7, 2010 | 06:12 PM
3truman's Avatar
i took mine off the car and sanded and painted it. make sure you sand and paint properly or it will flake, i have a few spots that flaked but i also used a flat black, should have used a gloss black to go with the b pillars. and be very careful when you remove the trim it can bend and wont go back together perfectly. but overall i messed up a few times but it still looks pretty good.
Old Sep 7, 2010 | 06:15 PM
texasg's Avatar
mine got done with vinyl and i wil take and pic and post it as soon as i can.
