traded my 03 coupe for 04 sedan
No, basically if you say putting an aftermarket exhaust it will grawl like the coupe, and make the car faster because it has 30lbs less. umm so to the A/T sedans will be driving around with some loud exhaust to get that coupe factory grawl... So i guess infiniti lowered the sedan prices for you sedan people can afford to get all these modifications.. not bad at all..
the starbucks drive through guy told me he loved my car...other then that I haven't driven anywhere where someone would compliment it. The is no infiniti dealer near me, most people don't know **** about cars and probably don't even know what my car is. but you are wrong, ask the coupe owners, they get compliments all the time...at least they did in 2003
seriously where are you that you are getting compliments on your sedan? My RSX got quite a few compliments I guess...and one guy in a blue mid 90s corolla who yelled that the color looked like ****in ****
idk I think you need to get a better camera so we can see how amazing all of your played out black things are
you mean the motor trend times? coupe 0-60 5.83 1/4 mile 14.23@99.4 sedan 0-60 5.78 1/4 mile 14.28@100.3
they are pretty much the same...honestly the only significant difference there is the sedan's trap speed being almost 1mph higher so I wouldn't go down that road if I were you. It basically means that the sedan is capable of a better time with a better driver and that the sedan has better top end.
realistically though its a drivers race, i doubt there would be a clear winner with 2 equal drivers
you probably think the sedan is faster because thats the fastest car uve driven. And because you own it. if 2 stock g35's (sedan n coupe) same year same mileage run down a quarter mile ill put down anything that the coupe will win dude.. just did the research on the weights, the 6mt sedan weights 3398 n the coupe weights 3435. 37lb diffrence.Now the coupe pushes 280hp, 20 hp more. So basically ur tellin me the coupe uses 20 hp to push extra 37lbs? common man..
that would work if the coupe actually had 20 more hp, but it doesn't they both make the same power, the 20 hp is a marketing ploy check out the dynos.
also i thing G35s are pretty slow. Ive driven lots of faster cars, my rsx had better top end, my bros camed gto with LS6 heads was much faster, my friend's sr20ve swapped b13 se-r is faster, my other friend's S4 was way way faster. If you think stock g35s are fast..lol well you don't know much about cars.
https://g35driver.com/forums/drag/16...ons-stock.html
fastest stock V35 on the forum was an 03 sedan
Stock VQ35DE
and with mods you can see that it doesn't really matter at all
you fail at your own car
and if you still think the sedan has 20 less hp then you didn't read this post
05-06 automatic sedans are rated 280 too, they didnt change anything, just raised the number
Stock VQ35DE
Reserved for Stock Entries for the VQ35DE
1. BobbyD --------- 03 - Sedan - 6MT - 13.84@101 ----- 2.040 60ft --- Verified --- Street --- -1200ft DA
2. Reidonly ------- 05 - Coupe - 6MT - 14.05@102.35 -- 2.193 60ft --- Verified --- Street ----
3. Dv8 ------------ 03 - Coupe - 5AT - 14.37@96 ------ 2.217 60ft --- Verified --- Street ---- ????ft DA
4. Buccaneer ------ 05 - Sedan - 5AT - 14.39@97.09 --- 2.198 60ft --- Verified --- Street
5. 06g35meister --- 06 - Coupe - 6MT - 14.40@96.9 ---- 2.253 60ft --- Verified --- Street ---- ????ft DA
NA/Bolt-Ons VQ35DE
Reserved for NA/Bolt-Ons Entries for the VQ35DE
1. trey.hutcheson - 05 - Sedan - 6MT - 13.264@103.96 - 1.895 60ft - Verified --- BFG DR's -- 975ft DA
2. Dsskyline ------ 04 - Coupe - 5AT - 13.495@101.69 - 1.933 60ft - Verified --- Street
3. abailey269 ----- 04 - Sedan - 6MT - 13.631@101.57 - 1.966 60ft - Verified --- BFG DR's
4. Rival ---------- 03 - Coupe - 6MT - 13.677@105.85 - 2.104 60ft - Verified --- Street
5. CarlosM -------- 06 - Coupe - 6MT - 13.750@101.31 - 2.042 60ft - Verified --- Street
6. Reidonly -------- 05 - Coupe - 6MT - 13.794@103.52 -- 2.157 60ft - Verified --- Street
7. GrayG35 -------- 04 - Coupe - 5AT - 13.840@98.77 -- 2.139 60ft - Verified --- Street
8. billybrun ------ 06 - Coupe - 6MT - 13.851@99.70 -- 2.013 60ft - Verified --- ET Street - 325ft DA
9. bosssho -------- 05 - Coupe - 5AT - 13.858@102.73 - 2.134 60ft - Verified --- Nitto DR's
10. Nismo G -------- 03 - Coupe - 5AT - 13.860@100.40 - 2.075 60ft - Verified --- Street ---- 985ft DA -
11. 06g35meister -- 06 - Coupe - 6MT - 13.899@98.99 - 2.153 60ft - Verified --- Street ---- 1260 DA
12. norcal_chan69 - 06 - Coupe - 6MT - 13.963@103.22 - 2.295 60ft - Verified --- Street
13. GinFLA -------- 06 - Coupe - 5AT - 13.966@98.06 -- 2.163 60ft - Verified --- Street
14. da_mayor ------ 06 - Sedan - 6MT - 14.002@100.46 - ?.??? 60ft - Verified --- Street
15. 06g35meister -- 06 - Coupe - 6MT - 14.034@99.99 -- 2.177 60ft - Verified --- Street
16. Crappyday ----- 03 - Coupe - 5AT - 14.053@99.28 -- 2.078 60ft - Verified --- Street ---- 703ft DA -
17. ikickpuppies -- 04 - Coupe - 6MT - 14.102@101.14 - 2.231 60ft - Verified --- Street ---- -177ft DA -
18. Klubbheads ---- 04 - Sedan - 6MT - 14.127@98.77 -- 2.172 60ft - Verified --- Street ---- 2468ft DA
19. 03BaseSedan --- 03 - Sedan - 5AT - 14.230@99.86 -- 2.154 60ft - Verified --- Street ---- 1243ft DA
20. Zerk ---------- 03 - Coupe - 5AT - 14.235@97.5 --- 2.155 60ft - Verified --- Street ---- 184ft DA -
21. SixFive ------- 03 - Sedan - 5AT - 14.254@97.18 -- 2.194 60ft - Verified --- Street
22. ELMACHOGERACHO- 05 - Sedan - 6MT - 14.295@99.45 -- 2.282 60ft - Verified --- Street ---- 1361ft DA
23. DaveB --------- 03 - Sedan - 5AT - 14.320@97.73 -- 2.158 60ft - Verified --- Street ---- 175ft DA
24. mike281 ------- 06 - Coupe - 5AT - 14.328@97.31 -- 2.258 60ft - Verified --- Street ---- 1567ft DA -
25. helldorado ---- 05 - Coupe - 5AT - 14.330@97.47 -- 2.150 60ft - Verified --- Street ---- -709ft DA
the sedan weighs less and actually has the same amount of power if you look at dynos
04 sedan with stillen exhuast and z-tube
350z with intake
pretty much the same despite the z being rated 287 and the G being rated 260...can't find a coupe but they don't dyno any higher then z's
350z with intake
you cant refer to the 6mt's thats all on the driver.. but look at the stats for a/t not much of a difference.. and yea i guess they can just say a coupe has 280 because they feel like it.. but the sedans are ugly looking and unperfected. Just the cheap version of the "G35s". dude i usto own a fully built gsr in a eg hatch turbo. running 748hp. g35s were cake..
omfegwin: They made the coupe 'appear' to have more HP so dumbasses like you would buy it so you could impress your friends.
You're car is:
1. More expensive.
2. Slower
3. Heavier
4. Hardly Any Backseat
5. More expensive to insure
6. 0 trunk space
7. More cop attention grabbing
You'r arguement FAILS! Just shut up and leave.
I AM STILL LAUGHING.
THIS DUDE IS SO FVCKING RETARDED ROFLMAO! I am litterlaly laughing my *** off and reading every one of his comments to my roommate. This is literally the thread of the century right here.
You're car is:
1. More expensive.
2. Slower
3. Heavier
6. 0 trunk space
You're car is:
1. More expensive.
2. Slower
3. Heavier
6. 0 trunk space
hate to say it but
honda owners ugh
how many stickers did it take to make 748hp?
