Hey guys. Need some help pretty urgently. I have been searching the interwebs and cant find anything so thought i would join up here and ask.
I have just purchased a v35 03 model. Apparently an ex *** drift car but i still think it needs a few things to make me happy with it.
Anyway, the drivers window wont go up or down. Passenger works fine. The drivers window drops that little bit when you open the door but i cant make it go down.
Im entering a drift day next week in it and need it to be able to be put down for that. Any ideas? Could it be a fuse? Or the switch?
Old owner said it was intermitent but after a week of clicking the button it still doesnt work lol.
Also does anyone know what these things are like to slide? I am used to drifting a fc rx7 with quite a lot of work done to it. Hopefully this will be more reliable lol?
Thanks in advance guys
Hi. Do you have a coupe or the sedan man?
Also for drifting, wouldn't it be better for it to be window up?
Anyways, your window motor is gone
https://g35driver.com/forums/faq-diy...attle-fix.html
Iono check that out or search bro
I have the coupe. Thanks for the help. I just hit the door repeatedly and managed to get it to go back down and then back up. Might work for a while. Just dont want it to die if it starts raining lol.
And window up is a pain to speak to people in other cars in the line up and alo gets very hot if you dont have the ac on lol
Your window regulator is going out. Its a very common issue with our cars. Easy fix just need to take off the inside panel of the door and replace.
Gl. I think there is a DIY or sticky on here about it.
