...I have come to the Dark Side
Old Jan 6, 2011 | 07:10 AM
  #46
jasonseoguam's Avatar
nice purchase
Old Jan 6, 2011 | 09:30 AM
  #47
FlyingLumpia's Avatar
Oh btw now that you have that sedan you have to make the trip to Cali for the sedan gtg this year.
Old Jan 6, 2011 | 09:50 AM
  #48
Matzo Ball's Avatar
holy ****, a 20 and a 25 series????? Go with a 35 front and 30 rear and you should be just fine. Bags may be a great idea as well, slam it when parked and raise for the drive
Old Jan 6, 2011 | 01:06 PM
  #49
The Stimulation's Avatar
Originally Posted by Beebo
id really like 35 since there are pot holes everywhere and i mean everywhere
How thin??? SO ****ING THIN
Thanks
maybe 305/35/20 more fender full and negative camber lol
I do...
will do
ahaha funny guy
google earth el paso texas and look at the roads
Looks bad....but try checking out Downtown LA, like the fashion district area. Plenty of roads like that in LA. Some pretty bad freeways too. One of them, Dre should know, the 134W going to the 5S, just as your getting through the last part of the curve, there is a good 3-4" drop. I took it at 30 mph yesterday and my front end just smashed to the ground...and to think, I kept on taking that at 60 mph lol.
Old Jan 6, 2011 | 02:25 PM
  #50
Beebo's Avatar
Congrats Beebs!!
Thanks
Originally Posted by ShanesG
Im right her secsi, flap flap
Originally Posted by jasonseoguam
nice purchase
Thanks
I plan on it, Aaron was telling me that at In & Out
35 front if i do that i may need to run a little stretch since the front already rub like crazy
damn hahaha
Old Jan 6, 2011 | 02:29 PM
  #51
Jeff92se's Avatar
Red Card Crew
Thanks
Amazing that a conversation could had during that.
Sorry had to.
Old Jan 6, 2011 | 02:38 PM
  #52
Beebo's Avatar
hahahaha
Old Jan 6, 2011 | 02:41 PM
  #53
khsonic03's Avatar
fronts are 245/30/20 which i may keep idk yet but the rears are for sure too thin 295/25/20
Dude, sick ride. Always loved that car.
Just an FYI though...the sidewall is an aspect ratio of the width of the tire. In the current setup, the rears actually have a taller sidewall than the fronts.
Here's the math:
Fronts:
245*.30=73.5mm sidewall
Total wheel rotating diameter = 25.78 Inches
Rears:
295*.25=73.75mm sidewall
Total wheel rotating diameter = 25.8 Inches
That setup is almost dead-on front and rear.
Old Jan 6, 2011 | 04:18 PM
  #54
Bestswat's Avatar
^Yea he did alot of research buying the tires for his car.
Old Jan 6, 2011 | 04:19 PM
  #55
CandlestickPark's Avatar
ill Sedan
Correct, just because its a 25 series tire doesn't mean its too thin, you have to consider how wide the tire is as well and look at the overall diameter.
Old Jan 6, 2011 | 04:33 PM
  #56
Beebo's Avatar
Here's the math:
Fronts:
Rears:
wow im a noob to this, what can i do to get more meat? either way i need more tire
any help would be greatly appreciated
Thanks,
-Wes
Old Jan 6, 2011 | 04:40 PM
  #57
Project's Avatar
Thanks,
-Wes
PM Socal i heard his good with that kind of stuff.
Old Jan 6, 2011 | 04:44 PM
  #58
Jeff92se's Avatar
Red Card Crew
Thanks,
-Wes
You might be fawked if the wheels are too wide. The only way would be to oversize the dia a bit with a 25 series? Other option would be to go to a thinner tire but I'm sure the rears are on their limit already. Or get a diff wheel/tire set up
Old Jan 6, 2011 | 04:49 PM
  #59
ill Sedan
^Yeah could run a wider tire on the 25 series, but he would have to add some negative camber so it doesn't rub. Fenders are already pulled. May have to raise it a tad too.
Old Jan 6, 2011 | 04:55 PM
  #60
G SEDAN's Avatar
if it aint broke, dont fix it!
If you're so adament on getting more sidewall (which you really wont, since you'd have to downsize the wideth, and in return stretch more)
I'd do 275.30.20 and 245.35.20 with a good stretchable set of tires. Otherwise, keep it the way it is bro, and just raise the car a lil bit. There isn't much you can do to a 20x11 rear.
The sizes I have are perfect front and rear....you cant add or subtract sidewalls without throwing off your speedo significantly, or throwing off your VDC.
and if you end up stretching more....it will look ugly because I have a lot of clearance left for even wider tires!
