Cruise Control Button
Old Jan 24, 2011 | 03:25 PM
kri015015's Avatar
My cruise control button on the steering wheel seems to be broken. My steering wheel is basically the same as this picture. (http://static.howstuffworks.com/gif/...el-1-3-480.jpg)
The right column, top button, the one that sets and also increases or decreases speed. Holding it down originally will set the speed, holding it down again will set it in coast. Those both work fine. Its when I try to push the button up. It won't make that clicking sound, and it seems like it has just been knocked out of position. Is there a way to fix it? Thank you!
Old Jan 24, 2011 | 11:07 PM
NFSP G35's Avatar
? = 2B || !2B
^Picture isn't working.
Also, I'm not sure what "clicking sound" you're talking about.
Old Jan 25, 2011 | 06:30 AM
kri015015's Avatar
Maybe this picture is better...
http://www.google.com/imgres?imgurl=...:0&tx=94&ty=60
Sorry for the long link...
When you press the top right button up and down, it sort of clicks to let you know you've pressed it up or down completely... Well when you press it down it "clicks" just as if youre adjusting the volume via the steering wheel up or down, but when you press it up it wont go up all the way... I'll try to upload a picture 2moro
Old Jan 25, 2011 | 06:57 AM
Eric@TCGMiami's Avatar
What year is your G?
The volume and cruise control buttons cost around 75.00 online. for my 2003 G Sedan.
Old Jan 25, 2011 | 07:09 AM
kri015015's Avatar
03 Sedan as well
Old Jan 25, 2011 | 07:14 AM
Originally Posted by kri015015
03 Sedan as well
http://www.trademotion.com/partlocat...layCatalogid=0
Clickity
Old Jan 26, 2011 | 08:31 AM
Mustang5L5's Avatar
Mine doesn't "click". None of my buttons do
does it work? in otherwords once you've set cruise, will tapping it up increase speed?
Old Jan 26, 2011 | 12:07 PM
kri015015's Avatar
No tapping it up wont work, but down does
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
BfloG35
Oct 16, 2015 05:22 PM
