Look at this, Let me know what you think.
Old Feb 21, 2011 | 12:28 PM
Songle6MT's Avatar
So as some of you know I am looking at getting a new car. I looked at this car last weekend and it is pretty clean except I am nervous about this rust.
I would just like some opinions on if it looks easily fixable or if I should stay away.
Old Feb 21, 2011 | 12:37 PM
007JD's Avatar
thats just rust .. i dont think that will effect anything
check the major things
engine , tranny , if its slipping or not
ac / heater / electrical
under the car .
crash reports and maint. reports
condition of inside
Old Feb 21, 2011 | 12:40 PM
Songle6MT's Avatar
under the car .
condition of inside
Thanks, I guess it just bugs me that it's by the strut mounts. Engine, tranny seemed strong, it is a six speed. I didn't notice any slipping but i found the high engagement point to be weird, I thought that was a sign of a clutch going out but I read on here that all of the 6mt have a high engagement point.
All the electrical stuff works, under the car is pretty rust free that I could see apart from the exhaust. I have the records up to 20,000 before it is at now and they are pretty clean, it is a 1 owner car no accidents reported. The inside was pretty clean.
Old Feb 21, 2011 | 02:06 PM
Wannabe6MT's Avatar
-MN G Crew-
I can vouch that the car was very clean (went on the test drive) but was also a little curious as to this rust around the strut mounts. It was really the only thing we could find for the most part.
Anyone else got a little rust up there?
Old Feb 21, 2011 | 02:20 PM
G35 Dream's Avatar
Looks as though the car sat for a long time or something. If it really bugs you get some new struts/mounts and clean up the rust. Check under that spot in the wheel well and make sure it hasnt started to eat through. IMO it looks like someone sprayed out the engine bay and let the water sit in there.
Old Feb 21, 2011 | 06:15 PM
Mustang5L5's Avatar
I wouldn't even really call that rust.
A little sanding and some paint and that will all go away
Old Feb 21, 2011 | 10:18 PM
Wannabe6MT's Avatar
-MN G Crew-
Nothin' like buying this car this weekend.
Old Feb 21, 2011 | 11:34 PM
Songle6MT's Avatar
If all goes well, that is a possibility
Old Feb 22, 2011 | 12:38 AM
007JD's Avatar
as stated before . probaly water down the bay. and left the water sitting there.
if everything else checks out . and if you like it go for it ..
but its tough buying a used car,.. because u never really know what can go wrong with it
just go with it ...
hope all works out
Old Feb 22, 2011 | 01:00 AM
MM_G3520's Avatar
My car has a slight hint of something similar to rust in those two spots as well. It's not a problem at all. I could probably get rid of it in on a lazy Sunday.
The car most likely spent a good portion of its life outside. Not a big deal, but that's what happens in parts of the country with real winters.
Old Feb 22, 2011 | 01:19 AM
The X Factor's Avatar
Time to buy.
Old Feb 22, 2011 | 01:32 AM
Songle6MT's Avatar
yeah i will probably end up getting it, but now i came across an 04 with the same amount of miles and navi, that looks super clean thats about 20 miles away from this one. I will probably come back with one or the other next weekend.
Old Feb 22, 2011 | 01:35 AM
Wannabe6MT's Avatar
-MN G Crew-
And your not going to tell me which one until you come strolling into the lot.
Old Feb 22, 2011 | 01:36 AM
Songle6MT's Avatar
I have to keep the suspense
Old Feb 22, 2011 | 12:31 PM
AARONHL's Avatar
Same rust on my whip!
