lost all power
Mar 2, 2011 | 11:22 AM
i tried to do the tb relearn and all those other resetting steps because i was having warm start stall problems. i must of did it wrong because after i did that my check engine light, slip, and vdc off, all came on. and there was almost no response when i press the gas. so i checked codes and it was throwing a throttle body position code. so i erased it and everything was back to normal. then today i was driving and lost all power it was just idling and all the lights came on again. so i pulled over erased the same code again and all is back to normal for now. so will it eventually relearn once i drive more or do i have to do something to fix this
thanks
Reply 0
Mar 3, 2011 | 12:07 AM
I'm having the same problem bro. Just to check it at Infiniti is $175?I want to fix the problem myself. I have a 2005 G35 sedan
Reply 0
