Turning Right Vibration!!!!!!
Old Mar 6, 2011 | 06:24 PM
kyemaul's Avatar
What's sup guys some of you guys have helped me before need some more help....
The problem I am having is when I drive my 03.5 sedan if I turn my steering right then it will have a vibration, this vibration accurs during right turns, lane change, highway driving, anything over 20mph. If I go left... lane change everything above then no vibration.
I took the car to get four tires and wheel alighnment and to have them check if anything is bent or bushings busted and the guy speed balanced all tires and checked if anything was busted and he said your compression rod bushing on the same side are busted ...so I changed them and brought the car back to get alighn n again same issue.
Does anyone think it could be the endlinks or anything...
All help appreciated!
Old Mar 7, 2011 | 04:33 PM
Mustang5L5's Avatar
Possibly wheel bearing. Would be the right bearing because when you turn right you put load on it. When you turn left, you take load off.
Old Mar 7, 2011 | 10:57 PM
kyemaul's Avatar
yea no one responded so i had it check that exactly wats rong with it, thanks
Old Mar 7, 2011 | 11:12 PM
Mustang5L5's Avatar
At least you are rwd....cheap easy fix.
I gotta do the front on my x.....expensive and a pita.
Old Mar 7, 2011 | 11:16 PM
kyemaul's Avatar
i had to change my rear axle and hub also not that cheap lol
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
master111
Sep 25, 2015 08:32 PM
