Hi all,
I've been trying to find Varrstoen wheels on the sedan with mild drop (1") and can't. The wheels are ES 2.2.2. model with 19x9.5 +22 and 19x10.5 +22 sizes...Can someone share any???
Thanks,
Thanks,
CandlestickPark
ill Sedan
close
- Join DateJun 2007
- LocationLong Beach, SoCal
iTrader Positive Feedback100
iTrader Feedback Score(87)
Liked:2,688 Times in 1,449 Posts
10.5 +22 will not look good with a mild drop. Need to be lowered at least 2.5", but preferably 3"+ for it to look good. All the Sedans that have run those specs in the rear are really low.
+1. When running that set up, you will need tire stretch and camber to make them fit properly. This wont look good with lots of tire gap.
If you like that style, check out JLB Motorsport Apollos. VERY similar design w/ more sedan friendly offsets if needed. Here is my car on Apollos with my odl suspension set up (drop 2" front and 1.5" rear)
19x8.5 +20
19x9.5 +25 (w/ 15mm spacer)
19x8.5 +20
I don't think JLB is in business anymore
Can't get ahold of them...all the #s are disconnected.
Can't get ahold of them...all the #s are disconnected.Do you think I can run Varsstoens with 9.5 all around? Or is it going to look pretty bad?
really?? I ordered mine back in October. That sux.Originally Posted by lox1985
Quote:
You could do it. They would sit pretty flush with your fenders all around. You would need your rear fenders rolled.Originally Posted by lox1985
If I was to source JLBs used with the sizes posted in earlier posts x8.5 and x9.5 +20, which tires would be the best?
You have a number of choices.
I would say 235/35/19 front and 255/35/19 rear. Depends if you like alot of meat to your tires or not. You could easily run a 275/35/19 rear but IMO that is too much.
Thanks Matzo...now I just need the wheels
It does suck that JLB went out of business...I've read good stuff about them and pricing was great.
Any other wheels that might look decent on a sedan with the lip in the rear?
So basically what the experts are saying is that my thought of buying varrstoens 2.2 at 18 x 95. with a 245 40 18 all around with a 1" drop (eibachs) will look like **** / wont work.
Or did I miss something?
