Auto Seat Problem!
Old May 4, 2011 | 02:39 AM
jattg35's Avatar
Angry Auto Seat Problem!
After disconnecting and fixing my battery cables, i went to reset my memory seat settings and then after i realized the auto seat when u enter and exit the car was working. i checked to make sure it was on auto and it was and the memory seats were set fine. If anyone has any idea to reset it or anything it would help. Its really frustrating. Its like a issue after a issue. s m h!
Old May 4, 2011 | 02:47 AM
thescreensavers's Avatar
Mr.202?
AUTOMATIC DRIVE POSITIONER
OPERATION
The automatic drive positioner system
has two features:
O Entry/exit function (only available on
models equipped with automatic
transmission)
O Memory storage function
ENTRY/EXIT FUNCTION (if so
equipped)
This system is designed so that the driver's
seat and steering column will automatically
move when the automatic transmission
selector lever is in the P (Park)
position. This allows the driver to get into
and out of the driver's seat more easily.
(This feature is not available on models
equipped with manual transmission.)
The driver's seat will slide backward and
the steering wheel will move up when the
driver's door is opened with the key or ignition
switch in the LOCK position.
The driver's seat and steering wheel will
return to the previous positions:
O When the key is inserted into the ignition
switch after closing the driver's
door, or when the driver's door is
closed after inserting the key into the
ignition switch.
O When the ignition switch is pushed
with the driver's door closed.
O When the key or ignition switch is
turned to the ON position.
Initializing entry/exit function
The entry/exit function can be activated
or cancelled by pushing and holding the
SET switch for more than 10 seconds
while the ignition switch is in the LOCK
position. The indicator light will blink
once when the function is cancelled, and
the indicator light will blink twice when
the function is activated. If the battery
cable is disconnected, or if the fuse
opens, the entry/exit function will be cancelled.
In such a case, after connecting
the battery or replacing with a new fuse,
open and close the driver's door more
than two times with the ignition switch or
ignition switch in the LOCK position. The
entry/exit function will be activated.
See if this works
Old Jun 27, 2011 | 01:06 PM
hi-tek22's Avatar
I know this is an old thread
I tried this on my 2004 X, It seemingly isnt doing anything, so im going to attempt it one more time....If that fails, looks like im going back to the dealership to take care of this issue!
derres
Aug 28, 2015 03:27 PM
Albanian122
Aug 18, 2015 05:15 PM
Pcruz
Aug 12, 2015 07:46 PM
realtalk21
Jul 20, 2015 09:07 AM
attarday
Jul 15, 2015 04:03 PM
