Alternative tires
Old May 26, 2011 | 07:34 PM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by 4D05G35
Cool, I'm on the same page.
So if the rear tire is drastically larger than the front it will effect VDC as well? Using your example of 5.78%.
I know having a smaller rear tire (aesthetics aside) is not good because it tricks the computer into thinking that the rear tire is slipping due to it spinning faster than the front. I have never ventured that far (rear more than 3% larger).
And yes anyone with experience please chime in, this is a good learning experience for all.
You got it.
Old May 26, 2011 | 07:37 PM
4D05G35's Avatar
Thank you sir.
Old May 26, 2011 | 07:48 PM
Blue Dream's Avatar
Happy to help............
Old May 27, 2011 | 04:03 AM
socialconflicts's Avatar
well i thought it was from oem specs. for example. befor ei got my oem rays 19s, i had sport 07+ sedan rims (18in rims) the frons were 50s and the rears were 45s. i checked before in the calculator and it was within 3% but my VDC was going crazy with that set up. so which is why i thought 3% from OEM Settings.
Old May 27, 2011 | 05:50 AM
Blue Dream's Avatar
Not sure why you had issues, what were the full specs on the tires you mentioned above?
Old May 27, 2011 | 08:35 AM
oem specs which i think were Fronts: 225/50/18 Rear 245/45/18
Old May 27, 2011 | 05:52 PM
d0nutboii's Avatar
^^I think 4D is correct. From what I've read factory diameters aren't the guide, it's the difference between the rolling diameter of the front and rear tires.
This link has a great calculator where you plug in the different tire sizes and it will spit out the specs for comparison and actually also create an image comparing the 2 sizes. http://www.miata.net/garage/tirecalc.html
Specification:215/55-17 and 245/35-19. Diameter: 26.3in and 25.8in. Difference 0% and -2.1%.
from what you guys are telling me, this would be alright. What I was originally wondering though was if it was alright to put the 245/35 on the front and rear which is .5 wider
thanks so much everyone for bearing with me. I know it could be stressful explaining everything to someone so inexperienced, but I am learning so much
Old May 27, 2011 | 06:19 PM
Blue Dream's Avatar
You learn quickly grasshopper. Your example is correct, that combination shouldn't give the VDC issues. And yes it would be perfectly fine to run 245/35 all around.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
