Guys I want to drop my car
Old Jun 4, 2011 | 03:29 PM
  #31
SN00P's Avatar
CLUB MODERATOR
You mean caption tora lolol rawrrrrrrrr lmao
Old Jun 4, 2011 | 05:30 PM
  #32
NFSP G35's Avatar
? = 2B || !2B
Keelhauled
Old Jun 4, 2011 | 05:43 PM
  #33
Epidel's Avatar
i salute you for the pirate talk toro
Old Jun 4, 2011 | 05:53 PM
  #34
nawalvicky's Avatar
get the eibach pro kits. its adds a little bit of stiffness but lowers it guud enough in my opinion. Also if your gonna start dropping start looking into camber kits to correct the alighment.
Old Jun 4, 2011 | 10:56 PM
  #35
ronniepetras's Avatar
I have an 03 sedan with coupe 19's what kinda coilovers should I go with nothing cheap looking for quality
Old Jun 5, 2011 | 02:53 AM
  #36
socialconflicts's Avatar
go with BC coils.. or stance.. those are quality.
Old Jun 5, 2011 | 03:16 AM
  #37
prinny's Avatar
You're probably going to have to get front and rear camber kits as well though.. that's like another $220+ AT LEAST for those cheap Godspeed ones.
Old Jun 5, 2011 | 03:26 AM
  #38
depends. if the toe is in spec, he doesnt need to worry much as long as he gets his tires flipped once the wear from the inside.
Old Jun 5, 2011 | 04:44 AM
  #39
I don't think I will be needing a camber kit I'm not slamming my car I'm looking at 1.5 in the rear and 2 front
Old Jun 5, 2011 | 09:30 AM
  #40
naijai's Avatar
If you are planning on lowering your car, you will need the camber kits especially the rear arms & toe bolts
Old Jun 5, 2011 | 11:03 AM
  #41
socalwdup's Avatar
Originally Posted by naijai
If you want to get springs for comfort I'll recommend eibach pro kit and tokico hp blue struts
What are struts? (srs)
please respect the serious tag.
srsly
Originally Posted by toro12
"Yarr, Your car wants to be dropped eh! I've been meaning to get the moar low and cheap message out.
Now yee can come in to the link (https://g35driver.com/forums/brakes-...coilovers.html) and meet the rest of the damned. Did I mention they're...dropped, in part are lost souls and with hundreds $ left in their pockets...?" Yarr
wat
Why do I need those? Becuase the tires will wear out in the inside?
Old Jun 5, 2011 | 11:45 AM
  #42
naijai's Avatar
Code:
Why do I need those? Becuase the tires will wear out in the inside ?
Yes it will faster than it is normally supposed to so if you'd prefer changing out tires more often then you are fine with just lowering it
Old Jun 5, 2011 | 02:23 PM
  #43
4D05G35's Avatar
srsly
Struts are on the front of your car, and shocks are on the rear.
Struts = spring and shock as one unit
shock = seperate from the spring, two seperate items.
Old Jun 5, 2011 | 03:02 PM
  #44
prinny's Avatar
If you drop an inch or more. You'll probably be needing one. You can always check after you get an alignment to see if your specs are really really close to OE, but you'd be wasting money if they aren't.
Old Jun 6, 2011 | 03:58 PM
  #45
gambit2083's Avatar
OK now you've got me curious. Would you mind measuring your fender to ground height in the F&R or do you know the dimensions?
...hmmmm me too, I wanna see a pic...
2004 Stock struts, shocks (red)
2004 350z sportlines
F-25.6" / R-24.9" (laser tape measure)
Unsettled, spring last year
Settled, spring this year
