Need your opinion on my 1st g
Old Jul 8, 2011 | 04:16 PM
IMDATBOI's Avatar
I have a 2000 acura 3.5 rl since 2003 which gave me no problems at all, and i'm a little bored with it. I have a chance to get a 2006 6spped m g35 for my birthday. The g is slightly smaller then the rl, but it's a 6sp m with 298hp, and it has nav, compared to my 225hp rl. Should i make the switch?
Old Jul 8, 2011 | 04:34 PM
Blue Dream's Avatar
I drove ttrank's car solo
Yes you should. Above all RWD > FWD
Old Jul 8, 2011 | 04:58 PM
artsVQ's Avatar
Do it!!!
Old Jul 8, 2011 | 04:59 PM
Invictus_Caelumfunis's Avatar
yeah do it.
Old Jul 8, 2011 | 05:11 PM
gtoor1990's Avatar
Do itttt
Old Jul 8, 2011 | 05:25 PM
silver9's Avatar
Is this a serious question?
Old Jul 8, 2011 | 05:36 PM
Wannabe6MT's Avatar
-MN G Crew-
Definitely switch.
Old Jul 8, 2011 | 05:44 PM
faiz23's Avatar
ummmm.....not unless you know the motor is solid. Keep in mind you are on "G" forum so expect everyone to tell you YES. I would make sure the engine has a good history of oil changes at 3,000 miles. Get a full service history from infiniti for everything done to the vehicle. Get an autocheck report NOT CARFAX, mechanic inspection / compression check, and a body shop inspection, Make sure there is some sort of warranty for at least 1yr on it. The specific car you are looking at has a HUGE TSB due to faulty motor design which leads to oil consumption and possibly seize the motor. Do your research of what to expect for maintenance cost. The G will cost much more than the RL and just look at the cost of tires every 30k miles.
Old Jul 8, 2011 | 05:49 PM
notorious_g35's Avatar
^^^^ +1
Always be as objective as possible when buying a car. But if you've test driven it, and you like it, then...
Old Jul 8, 2011 | 07:29 PM
IMDATBOI's Avatar
YUP, DEAD SERIOUS! I need input on it,because this my 1st infinit rear wheel drive car.
Old Jul 8, 2011 | 07:32 PM
IMDATBOI's Avatar
Thanks Homie. You input was real helpful.
Old Jul 8, 2011 | 09:19 PM
xXThirty-FiveXx's Avatar
hey bro,get the G! But id try and get the coupe not the sedan.
Old Jul 8, 2011 | 09:23 PM
infinitig35's Avatar
I hate FWD. It's either RWD or AWD for me. So I say just do it, but check the G35 carefully before you make the switch.
Old Jul 9, 2011 | 12:21 AM
JosansG35's Avatar
Not only is the G faster, but it looks better too!
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
Kelvin Style006
May 23, 2016 03:47 AM
