Need someone with a scanner to compare readings
Old Aug 4, 2011 | 05:06 PM
G35nNJ's Avatar
Ok needs you guys help again...I need to know what your MAF sensor is reading at idle....my idle is 730 - 750 with a MAF reading of 0.49 LB/M
Thanks for your help!
Old Aug 4, 2011 | 05:26 PM
DaveB's Avatar
A warm idle should be in the 600-650rpm range. Have you messed around with the throttle body recently?
Old Aug 4, 2011 | 05:44 PM
G35nNJ's Avatar
It's a long story DaveB, but my idle is set up that way (flashed)...my question is about the MAF reading
Old Aug 4, 2011 | 06:50 PM
VQEric's Avatar
On a hot engine at 650 rpm, my MAF reads about 3.6 g/s (gallons per second, I assume). Not sure how that translates to lbs/m.
Old Aug 4, 2011 | 07:10 PM
G35nNJ's Avatar
Thanks for the info, from the conversion calculator I'm looking at 3.6 g/s (gram/second) is 0.48 lbs/m so I guess my MAF sensor is reading correctly
Thanks
Old Aug 4, 2011 | 08:38 PM
VQEric's Avatar
No problem...grams/second...lol on me.
Old Aug 4, 2011 | 08:42 PM
G35nNJ's Avatar
Hey the only way I knew was because I was reading the conversion chart
Old Aug 6, 2011 | 02:31 PM
NFSP G35's Avatar
? = 2B || !2B
Yeah... so gallons are not a measurement of mass... and it is a Mass Air Flow sensor... just sayin
Old Aug 6, 2011 | 02:47 PM
NFSP G35's Avatar
? = 2B || !2B
Oh also, I just checked mine...
1000 RPM (just started) 1.2 lb/m
725 RPM (idle w/ AC on) .8 lb/m
650 RPM (warm idle) .5 lb/m
Old Aug 6, 2011 | 06:25 PM
G35nNJ's Avatar
Hmm is this the OEM airbox with stock filter? K&N?
Old Aug 6, 2011 | 06:59 PM
NFSP G35's Avatar
? = 2B || !2B
^No. it's an aftermarket long-tube CAI and conical filter.
Old Aug 6, 2011 | 07:12 PM
G35nNJ's Avatar
Your readings sound like volts not lbs/m
Old Aug 6, 2011 | 07:16 PM
NFSP G35's Avatar
? = 2B || !2B
Old Sep 7, 2011 | 02:30 PM
exiledtrinib0y's Avatar
my idle is close to 500 rpm not sure if this is normal but makes my car quiet at idle sometimes i fool my wife into thinking its off
Old May 19, 2014 | 10:31 PM
G35xStudent's Avatar
I'm at a warm idle with 800rpm and a .56-.58 lb/m stock airbox with k&n filter. Just cleaned the filter, do I need to add more filter oil to it? Lessen the airflow freedom? The Check engine light got thrown on a few minutes ago.
