What Size is This?
Old Oct 14, 2011 | 09:04 PM
JosansG35's Avatar
What Size is This?
This is one of 2 screws that hold down the motor-cover, and there are 2 more the are on the sides of the upper and lower plenum.
I broke one of these that belongs on the plenum and I need the replace it. Anyone know the size of this particular screw?
Any help is greatly appreciated.
Old Oct 14, 2011 | 09:27 PM
sdnpaul5at's Avatar
Pretty sure its's 10mm.
Old Oct 14, 2011 | 09:41 PM
JosansG35's Avatar
Yeah it's 10mm, but I need to know the length of it and the thread style, etc.
Old Oct 14, 2011 | 09:56 PM
r1forever80's Avatar
10mm is the size of the socket or wrench you use. 10 mm is not the size of the stud. Its 6mm x 1.00
Old Oct 14, 2011 | 10:09 PM
JosansG35's Avatar
There we go!! Thanks!
Old Oct 16, 2011 | 09:56 PM
soad's Avatar
Yes this Is correct. Its not a 10mm but for some strange reason I knew that the 1st answer was going to be 10mm
Old Oct 17, 2011 | 03:10 AM
JosansG35's Avatar
Psychic o.0
I ended up using one of the same bolts that goes into the other holes of the plenum. Seals just fine
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Detailed Image
Sep 18, 2015 03:43 PM
