Aux port?
Old Oct 17, 2011 | 06:50 PM
thebonafortuna's Avatar
Aux port?
Hey guys, I have an '06 G35x with the standard radio (not the Bose system). I'm debating installing satellite radio, but before doing so wanted to check whether the stock radio deck has an available Aux port to plug into - does anybody know?
Old Oct 18, 2011 | 03:13 AM
mwraider's Avatar
local
if you go to any local car audio place and tell them what year and details they'll know what one to grab. it's the nissan converter (~150) and typical install same day $100. Installs in trunk, can't see it. wired up to center console or glove depending on where you tell em. and comes with ipod hook up and 3.5mm jack. iPod connect u can use steering wheel too. And this takes place of Satellite channel 1. Best option out there man. Way cheaper than aftermarket double din. just the plastic dash piece is like 240. anyways, just go to local shops. if they good they'll know what's up.
Old Oct 18, 2011 | 11:13 AM
See, this is the value of these boards. I went to a local audio shop notorious for being a bunch of D bags, and they insisted I needed something called a "Cross Loop" (or something along those lines) to amplify the signal to do anything with my stock radio.
Is this the part you're talking about? http://www.crutchfield.com/p_581PA11...ce.html?tp=120
I'm taking a car maintenance class after work at a local vocational school, and would like to try and do the install myself.
Thanks much for the recommendation.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
stratous01
Oct 7, 2015 10:19 AM
dpark0223
Sep 11, 2015 02:17 PM
Freedz
Aug 28, 2015 07:38 PM
Cacoepy
Aug 3, 2015 01:09 PM
