Piaa Wheels. what ya think?
Old Oct 19, 2011 | 11:06 AM
4D05G35's Avatar
Drop it a little more, add about a 10mm spacer to the front, and set the rear camber to about -2 degree's...maybe a slight pull if you want the rear flush and you're good
Old Oct 19, 2011 | 12:07 PM
SDGenius's Avatar
Love the PIAA's, it's just tough because the rears are so much more aggressive than the fronts. fronts sit pretty perfect, could even fit more tire up there but the rears need the stretch and will prob need more than an inch extra drop to make them sit right. so you could either slam ur car like Grant had his OR you could ask Grant to do a HARD pull on your rears and instead of slamming it, you might be able to add some more tire and only drop it another inch to inch & a 1/2 to even things out. either way, once Grant get's you dialed in, i'm sure it'll look SICK.
Old Oct 19, 2011 | 12:23 PM
socialconflicts's Avatar
The current tire setup is from grants 235. I wil br running 245 or may do 255 depending what grant tells me. Other wheels that i do love are the 5 zigens. Like the one blue dream is rocking. I have seen others and i really like the spoke going all the way cuz it makes the rims look bigger rather than smaller.
Old Oct 19, 2011 | 12:26 PM
Songle6MT's Avatar
I dig it! I think they look good. Wider tires or a drop would help but isn't necessary IMO.
Old Oct 19, 2011 | 01:10 PM
well for sure wider tires.. but im almost positive a drop will be needed.. either for the front or rear.. ima need to get more informed on what tires too. i love fatty tires
but these were my other options. i was debating before grant told me about his wheels.
or which are sadly discontinued..
Old Oct 19, 2011 | 02:50 PM
Beebo's Avatar
i love the piaa's
Old Oct 19, 2011 | 03:11 PM
G35Papa's Avatar
Some inspiration for your drop
Old Oct 19, 2011 | 04:01 PM
the thing i feel is that the wheels dont "pop" as much.. primarely because of the color of my car, i know the chrome lip helps to distinguish the greyish but idk.
Old Oct 19, 2011 | 04:18 PM
G35Papa's Avatar
The pop you are talking about might have to do with a nice BBK behind such an open face. I like the wheels as is as well though.
Old Oct 19, 2011 | 04:32 PM
Wilg35j's Avatar
I like your face choice too, what brand are they
Old Oct 19, 2011 | 04:37 PM
CandlestickPark's Avatar
ill Sedan
The wheels look VERY good on your car, go for it! I would definitely go with a spacer up front and larger tires. You don't need to run a 235 to clear these out back. And like you said, go lower for sure will look dope!
ill Sedan
See the thread title.
Old Oct 19, 2011 | 04:38 PM
the ones i posted on the top are both 5 zigen wheels. the first are the ZR+520 second are the discontinued 5 zigen gravis 1.
atm the only thing im like ehh about is going back to square one..
Old Oct 19, 2011 | 05:32 PM
Wilg35j's Avatar
The piias werent his first choice.
Old Oct 19, 2011 | 05:58 PM
  #30
supreme1911's Avatar
Personally I like the stretch look and will be going stretched myself. But to me I think the rears can be less stretched and front a little more stretched. After that it will look perfect. Oh yeah and mooaaar low!!
