help with my headlight issue pleasee
Old Oct 24, 2011 | 11:37 PM
d0nutboii's Avatar
Originally Posted by r1forever80
wasnt wired right or wrong parts. It got too hot. Never had that happen on any of my retros
hmm thats odd, its a quad setup, and only one went out. Could the 55w ballast be the cause of this?
Old Oct 25, 2011 | 12:46 AM
r1forever80's Avatar
It mayb a quad set up but if your are using your oem lights you are probly using the oem ballast and ignitor up top and the 55w ballast is down low. If you gonna runn 55w ballast you should use the relay harness. Probly not enough power of the oem wiring to power the 55w ballast. Eventually it might fry the oem wiring
Old Oct 25, 2011 | 03:05 AM
d0nutboii's Avatar
thanks for sharing your knowledge. I really appreciate the input. the headlights are aftermarket with fx projectors and Tl projectors. fx are run by 35w ballast and Tl are run by 55w ballast. Both run through a relay harness and the picture was taken of the relay harness where it connects to the ballast. do you think maybe the ballast fried the relay harness's wires?
Old Oct 25, 2011 | 04:02 PM
d0nutboii's Avatar
just sent TRS an email, lets see what their input is
Old Oct 25, 2011 | 11:14 PM
outcasted g's Avatar
i think its cause you need to buy new wheels chris
Old Oct 25, 2011 | 11:15 PM
and DDM sucks!
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
bTanz
Oct 15, 2015 02:31 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
