some warning lights ON and stuck in Park
Old Nov 11, 2011 | 05:20 PM
satmar's Avatar
Unhappy some warning lights ON and stuck in Park
Hello guys, I need your help here, this is the problem: I drove my G35 to store for shopping, when I come back started the engine and try to pull the shift lever to R and... I couldn't and I noticed that ABS, SLIP and VDC lights were ON and the lever was stuck in P after looking for something thin to get into the hole that releases the lever I finally got home, but the help I need is: how can I get those lights OFF and put the shift lever in working order back again, thanks guys for your help.
Old Nov 11, 2011 | 06:13 PM
DaveNYC's Avatar
How did the car start as in turnover? Could be a number of issues. Brake fluid low, brake pads/rotors worn.low. Bad Crankshaft senor/camshaft sensor these two would cause a rough start or numerous cranks. If you can go get a code check. Goodluck.
Old Nov 11, 2011 | 10:15 PM
satmar's Avatar
Thanks DaveNYC, but I have the solution to my problem and I think this is worth to post, at the beginning I felt lack of electrical power to the shift lever, 'cause when you engage the brake to shift from P to R or any other speed you can hear a "clic" inside the ****'s lever and I didn't hear it so I took a very close look to every fuse in the box underneath the dashboard and...VOILA!!! I found the culprit 10 amps fuse burned belonging to "brake lights" I just replaced it and is working just fine. I hope this can be useful for any other G35 driver enthusiast.
Old Nov 12, 2011 | 06:25 AM
Blue Dream's Avatar
I drove ttrank's car solo
Great job satmar!! Thanks for posting the fix.
Keep an eye on that fuse though, something caused it to burn out and might be the start of a more serious issue.
Old Oct 19, 2012 | 08:10 PM
rickyk's Avatar
fuse went on me today too, came back from work last night and this morning started the car no problem and as soon as i put my foot on the brake to reverse all the warning lights came on and i couldnt switch gears. switched out the fuse and im back on the road.
arora_g35
Apr 16, 2026 02:52 PM
Mry
Mar 3, 2023 01:03 AM
11bEMT
May 27, 2022 03:13 PM
mjfenix
Jul 17, 2015 02:07 PM
