Shifting Issue (Automatic transmission)
Old Nov 18, 2011 | 06:32 PM
fsiddiq3's Avatar
Hello all,
Not sure if this is posted elsewhere or not but I have a issue with my shifter. I have a 06 Sedan with around 98,000 miles. When I turn the car on, I have to wait about 30 seconds before the shifter will unlock so I can put the car in reverse or drive, I am not sure why it does this but its very annoying. Does anyone have any suggestions?
Old Nov 19, 2011 | 01:34 AM
OCG35's Avatar
may seem like a silly question - but are you applying brake in the first 30 seconds?
Old Nov 19, 2011 | 12:46 PM
fsiddiq3's Avatar
Yes I am. Actually what is weird is that if I apply the brake and let go, and then apply the brake again the shifter will go into reverse or drive. Not sure what the issue could be
Old Nov 19, 2011 | 01:39 PM
OCG35's Avatar
possible faulty shift lock relay or solenoid?
There's a section in the FSM that has a series of trouble shooting procedures - it's probably easiest to have a dealer check it out.
Old Nov 20, 2011 | 11:22 PM
racermp's Avatar
Could be a bad brake switch too. See if some can stand in the back and see if thebrake lights are on when you start the car or have the shift problem. If they r on. Then iys the solenoid.
Old Nov 24, 2011 | 03:06 AM
champion408's Avatar
Bump to find a solution
Old Nov 24, 2011 | 03:28 AM
mikhaelbt189's Avatar
get aftermarket shift. those are without locks, so u can just switch to whatever u want right after u turn on the car. lol
JG_G35
Accessories
Feb 25, 2016 01:44 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
derres
Aug 28, 2015 03:27 PM
Srinidhi
Aug 7, 2015 03:38 PM
newbdriver01
Jul 15, 2015 06:10 PM
