coupe 19s on a sedan questions
Old Jan 18, 2012 | 11:55 PM
ericnismo209's Avatar
05 sedan 6mt dropped on 350z tein s techs.
im about to put some coupe 19s f-225/40 r-245/35 and i want to know what kinda of drop i will get. tire tuck? any or none at all. will i need spacers?, how many mm if so & camber kit???
right now i have oem 18s and in the rear i have 1 finger gap, if that helps..
Old Jan 19, 2012 | 05:35 AM
Blue Dream's Avatar
I drove ttrank's car solo
You'll have no tuck with the s techs. You will need to roll your fenders, at least in the back because the offsets on the coupe 19s provide a great fit on 1st gen sedans. Here's a pic of mine on G s techs, z struts, and coupe 19s.
Old Jan 19, 2012 | 02:50 PM
NjMatteSedan's Avatar
You will not need a fender roll. I have the same wheels with wider rear tires, same front tires. My rear tires are 255/35/19 and they don't rub at all. You should put some spacers though for a better look, if you do put spacers in the back you should roll them for sure.
i have 10mm spacers in the front and there's no rub. So i'd say put 10mm front and 15mm back and roll the rears
Old Jan 19, 2012 | 07:21 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
This^
You will not rub unless you add spacers, I am sitting on 350z H.tech, 225/40 and 245/40 with no rubbing issues,
Old Jan 19, 2012 | 11:20 PM
@ Blue Dream, do you have sedan s techs? as you may know springs made for a 350z and put on a sedan give a extra 1in drop, so if sedan s techs give a 1.5-1.7 with 350z s techs youll have a extra 1in so 2.5
just saying haha
@BlkSedan4me , can you post some pics up? after i get the 19s im going to put 255/35 as well
& probably the same mm spacers but im unsure on how they will look
Old Jan 20, 2012 | 01:03 AM
Ill post some up tomorrow. He had H techs in those pics. He's on coilovers now and different wheels. I have sedan S techd
Old Jan 20, 2012 | 07:43 AM
Blue Dream's Avatar
Those were actually the S Techs but the rest of your post is accurate. OP do yourself a favor and just get coils, if you're like a lot of us you will thank yourself in the future. I thought I wanted a slight drop so I started with H techs, then went to the S techs and Z struts, and finally bit the bullet and bought a nice set of coils. I should have listened to my advice from the get go. Here's how my car sits now.
Old Jan 20, 2012 | 08:44 AM
JaE35's Avatar
Moderator
G35 Sedan
i don't know why everyone elses car looks so tall with z suspension but i'm definitely tucking tire in the rear....04 Z suspension with 350z s-techs
245-40-19 all around
Old Jan 20, 2012 | 08:56 AM
blklude98's Avatar
pics when I had oem 19's with G coupe rear shock/spring, G sedan sport shock + z front springs
Old Jan 22, 2012 | 09:23 PM
butkiss1's Avatar
I'm on K sports .can go way lower but my rookie bumper don't like that to much
Old Jan 23, 2012 | 09:44 PM
EMAN44's Avatar
I think my car might be messed up because I was rubbing like crazy before I dropped. Tonight I installed my 350Z Eibach Sportlines on 350Z KYB struts and when I placed the car back on the ground, my rear fenders were literally resting on my rear tires...I sorta had to ghetto roll/bend/maul my rear fenders so I could get some kind of clearance so that I could drive it around and get a real fender rolling session. FYI my rear tire size is 245/40/19...thinking maybe the 40 series sidewall is the problem...
Emanuel
Old Jan 23, 2012 | 09:52 PM
JaE35's Avatar
Moderator
G35 Sedan
Dont abuse your fenders to fit rays its not worth it. Buy a camber it and add some negative
Jusseth
Sep 13, 2020 12:25 PM
R350k5
Oct 1, 2015 08:41 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
mushu
Jul 15, 2015 03:55 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
