Suspension help for 04 g35 Sedan
Old Jan 26, 2012 | 10:53 AM
1arko23's Avatar
Cool Suspension help for 04 g35 Sedan
Hello
I wanted to ask what is the best and most inexpensive way to lower my G.
Is it possible to put on all 4 350z springs instead of going with the 350z / G35 Coupe springs.
Thanks
Old Jan 26, 2012 | 11:00 AM
Peoria35sedan's Avatar
Look at the first page of the suspension thread it shows both Z/G and all Z.
Old Jan 26, 2012 | 11:01 AM
JaE35's Avatar
Moderator
G35 Sedan
z springs would be the cheapest option...you can install all 4 just be prepared to be a tad bit lower in the rear than the front
Old Jan 26, 2012 | 02:43 PM
Blue Dream's Avatar
I drove ttrank's car solo
Can't have both. Set your budget then shop for the "best" in that range.
Old Jan 26, 2012 | 07:45 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
The Z drop should be somewhere between $50 and $150 depending if you get just spring or springs and shocks. Your OEM Sedan shocks will wear down faster due to the Z's higher spring rates. Look for '04.5 and higher Z springs, these came with the revised suspension.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
Carlos_G358696
Jul 18, 2015 03:22 PM
