How to maintain A G?
Old Mar 20, 2012 | 08:21 PM
Reedtc's Avatar
Today I purchased my first G ^_^
I need to know how to maintain it tho :/
I know it need synthetic oil(only) change every 3-5 K miles
I need to know all le info to keep it running like butter
Old Mar 20, 2012 | 08:49 PM
X-Rated's Avatar
Great thread ! It's my first G too soooo subscribed! Dig it
Old Mar 20, 2012 | 09:00 PM
herrschaft's Avatar
Browse this forum and: http://x.infinitihelp.com/forum/maintenance.php
Old Mar 20, 2012 | 09:11 PM
jhaddad112's Avatar
Well besides routine maintenance, personally I usually warm up my G for about 2 minuets when the engine is cold, always fill up with 91 gas, inspect the fluids every so often, and make sure to listen for any unusual engine noises.
Old Mar 20, 2012 | 09:52 PM
Reedtc's Avatar
Originally Posted by herrschaft
Thanks
Thank's I will do.
Old Mar 20, 2012 | 10:32 PM
5150DS's Avatar
Who told you synthetic only? Nissan actually recommends dyno oil. If you are changing synthetic at 3k miles, you are throwing your money away.
Old Mar 20, 2012 | 10:52 PM
Reedtc's Avatar
The automotive guy, said I should change oil & filter using synthetic oil every 5k miles to keep her running like butter..
Old Mar 20, 2012 | 11:09 PM
5150DS's Avatar
5k is what I do, but you put 3-5k. As for oil, synthetics main benefit is the increased drain interval. Modern dyno is comparable to most synthetics since few are true synthetics.
Old Mar 21, 2012 | 12:55 AM
TunerMax's Avatar
G35
Just a note, you're actually best not to let your car idle to warm up. The best way is to start the car, and start driving right away once the idle settles. And just drive slow keeping revs down until the engine reaches operating temperature.
You can speed up this process by keeping your heater off until the engine is warm as well.
Idling your car is bad, idling the car when cold is worse, 2 minutes is hardly a long time, but if you're doing this stricktly to 'save' your engine, then don't bother, you're much better off doing as recommended above
Old Mar 21, 2012 | 11:09 AM
OKStateG35's Avatar
Interesting, what's the reasoning behind not letting your car idle to temperature? Not questioning it, just curious
Personally I do the start up, let revs drop and go method and my wife still thinks I'm weird for even doing that. She's one of those that starts it up and goes along with 99.9% of the general public.
Old Mar 21, 2012 | 01:14 PM
VQ35DE215's Avatar
X2 on this, i always let my motor warms up before i drive it and now since you brought it up, im wondering why?
Old Mar 21, 2012 | 01:21 PM
GR6RR's Avatar
+1 on the infinitihelp.com site.... Some things you will learn from there.
Old Mar 21, 2012 | 01:39 PM
Theory_EK's Avatar
Idle adds more wear on your motor the cooler it runs the faster it wears. Cars now a days are meant to be started and driven. Idling you car in the morning is a thing in the past.
Old Mar 21, 2012 | 05:03 PM
TunerMax's Avatar
G35
Below is a good basic explaination, thanks Theory_EK
We all know heat expands most objects, the alloys/steel etc in your engine bay are no exception. This means when cold, the engine components are undersized, which causes excellerated wear.
Also, most know that idling your engine and starting your engine are two of the worst things for it.
By letting your engine idle when cold, after a cold start, you're combining the two worst things for your engine, with a bad variable, cold temperature.
There's more precise reasoning behing why driving it and keeping under 2k RPM as much as possible is far better than idling when the engine is cold, but I'm likely not the best guy to explain it, and it's kind of irrelevant unless you're realy interested in it.
Old Mar 21, 2012 | 05:15 PM
VQ35DE215's Avatar
thank you for the explanation. no more warm up now haha
