Bc coilover squeak
Bc coilover squeak
Noticing a squeak coming from my front drivers side BC coilover when I go over small bumps and imperfections on the road. I have less than 10k miles on these, can they be going bad already? Maybe the top mount is loose or something? I rocked(bounced) the car on both sides and the sound on the drivers side is pretty loud, I did the same on the passenger side and it did the same sound but it stopped after a couple of rocks.
I posted a link below of another vehicle that has the same exact squeak.
Any help would be appreciated.
http://www.flickr.com/photos/67686236@N06/6449551807/
Ugh, not good. I was planning a BC BR coil drop soon.
Did you check and make sure bolts were all tightened well? Sometimes you'll have issues after a recent install.
Metal on metal kind of sound? or more of a bushing type noise? COMPRESSION RODS?
^ Haven't had time to check if the bolt on the top mount is tight, will do it this weekend. Doesn't sound like metal on metal, check the video out, I have that same noise.
I've had these on for almost two years, haven't had any issues until now. Hopefully is nothing major that will need replacement.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
