Veilside Andrew Evolution 5 wheels
Old Jan 6, 2005 | 12:44 PM
TonyZ_G's Avatar
i was wondering if anyone had these rims on a sedan....
if so can i see pics pls...
Old Jan 6, 2005 | 01:47 PM
TonyZ_G's Avatar
u can find the pics of em at www.hopupracing.com
Old Jan 6, 2005 | 01:48 PM
TonyZ_G's Avatar
full link http://www.hopupracing.com/veanevv.html
Old Jan 6, 2005 | 02:18 PM
Gsedan35's Avatar
Something tell's me it's a rim that are offered in coupe offset ranges and not sedan offsets.
Old Jan 6, 2005 | 07:22 PM
TonyZ_G's Avatar
=/ sorry kinda new at this... so wat is the sedan offsets..
Old Jan 6, 2005 | 11:54 PM
Boon's Avatar
I believe the stock sedan offset is 45. Try and stay with an offset of 38 or higher (40,45, u get the idea) and you should be fine. Anything under 38 and you will more than likely be sitting outside the fender quite a bit. I just did 38 front on 8.5 wheel and 45 in back on a 9.5 wheel and it fits perfect. Hope this helps a little.
Old Jan 7, 2005 | 02:41 PM
TonyZ_G's Avatar
thx... got a better idea now then before.....
Old Jan 7, 2005 | 03:10 PM
TonyZ_G's Avatar
so how do u figure out the offsets... wen i look at rims it only says 19x8.5 19x10 and so on.....
Old Jan 7, 2005 | 05:44 PM
Swifty's Avatar
dont worry when you order veilside will make it to the right offset. It's a 3 piece wheel, so it can be made for coupe or sedan...if you have AWD you may want to note that too, also if you will be upgrading your brakes.
Old Jan 7, 2005 | 10:27 PM
TonyZ_G's Avatar
really ? so it can fit a sedan ? thats cool then
andrewvk
Interior
Aug 6, 2015 05:51 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
