From an insane 10.8mpg to a mindblowing 8.7mpg -_-
Old Apr 1, 2012 | 12:32 PM
Threepoint5's Avatar
Thumbs up
Originally Posted by TunerMax
Yes, it will. Your alligment being off has a HUGE impact on your mileage dude.
You cannot go off the on-board readings. Do nothing until you get ACTUAL readings by calculating Miles travelled per Gallon consumed. Also, you didn't say what sized tires you have, are they the same diameter as stock?
Do the calculation for MPG by:
1. Fill the tank. Note where you fill up, you'll want to return to the same pump if possible.
2. RESET your TRIP odometer on your dash.
3. Drive for however long you like. It's recommended to run close to empty so you get an accurate idea of fuel consumed across a tank.
4. Return to the same pump and fill up again. Record Gallons to 'full'. Record Miles travelled from TRIP odometer
5. Divide miles travelled (TRIP mileage) by Gallons used
6. Now you have your ACTUAL mileage. Repeat this if you like a few times to get a more accurate average mileage.
Example:
1. Full tank
2. TRIP = 0
3. Almost empty tank
4. Filled tank.
350 Miles travelled on TRIP
20 Gallons to fill up tank
5 350 / 20 = 17.5
6. 17.5 MPG
^^Are the VC's that expensive???? The Maxima's (6th gen version) are only like $30-40 for the whole thing with built in new seals........ just curious.
Thanks alot for the info, will do ... I'm currently running coupe 18' sport 225/45F 245/45R dropped on H&R's.
Old Apr 1, 2012 | 05:33 PM
chink-ah-saur's Avatar
Yea it's a little different from the max ones.
They are like 150 for a DIY one.
And 200 something with $150 for core return
Old Apr 1, 2012 | 07:01 PM
TunerMax's Avatar
G35
Originally Posted by 5150DS
Yes, they are 2-3 hundred each I believe.
Ouch!!
That's rough, glad mine aren't leaking
(Knocks on wood)
Old Apr 1, 2012 | 11:13 PM
SuperTrooper699's Avatar
Did you check the gaps of your spark plugs before you put them in?
Old Apr 2, 2012 | 02:24 AM
Well I purchased Some NGK Iridium and to my knowledge the plugs comes already pre Gapped. The most I did was to line them up with the old ones to see if there was any difference in the gaps but it seemed fine.
Old Apr 2, 2012 | 02:48 AM
herrschaft's Avatar
^You should always measure the gap before installing new plugs. Not saying this is the problem just FYI.
Old Apr 2, 2012 | 10:48 PM
AARONHL's Avatar
Put air in your tires
Old Apr 3, 2012 | 11:30 PM
TexasNiceGuy's Avatar
Insane mpg problem
Dude something must be serious going on. I just got done driving from Houston, TX to Dallas. I did it on 2/3 a tank and average speed of 95 mph. My day to day driving around town and on the highway here in the DFW I get 24mpg. I'm driving an 05 6mt with 95k miles on her, and she begs for more. I would recommend pulling those new plugs back out and set the gap and as recommended in your owners manuel. Most come pre-gapped but the gapping issue can cause serious mpg issues. I would also recommend resetting the ECU- ie., take the ground off the battery for a couple minutes. If that doesnt help post back.
Old Apr 4, 2012 | 06:58 AM
TunerMax's Avatar
G35
Lol, incorrect spark plug gap is not going to cause 8-11 MPG, wtf boys.
It's probably just a messed trip computer imput. I bet when he calculates it it's a whole different number.
Old Apr 4, 2012 | 10:22 AM
helpful info, will try..
Old Apr 4, 2012 | 10:24 AM
I was thinking the same thing but ill definitely report back with the calculations.
Old Apr 4, 2012 | 10:34 AM
freakta's Avatar
Bad cats cause huge mpg problems and with fouled out plugs I'd suggest that first... Gap the plugs get an alignment put some air in the tires and then do manual math on the mpg...
Also the m6 cars do way better mpg than the a5. My a5 got a best of 24.4 from dc to Boston. In 6 hours
Old Apr 4, 2012 | 10:46 AM
I was interested in purchasing some test pipes so do you think thats a good way to go or should i replace with stock cats?
Old Apr 4, 2012 | 10:55 AM
freakta's Avatar
Test pipes need to be tuned for, so if you have them when you put them on make sure you have 500 extra bucks to tune it correctly.
But yes they free up hp and mpg. If they are clogged the car would seem pretty normal while driving just be a bit low on power and horrible on fuel cause most cars dump fuel to fool things off like a cat or pistons
Old Apr 7, 2012 | 08:30 AM
  #30
I don't know about having to tune it, but I'd suggest test pipes or HFC before putting another set of those restrictive stock cats.
