Few Questions
Old Apr 15, 2012 | 01:01 PM
Mecandris's Avatar
Few Questions
Hi guys, I am new to this forum and have few questions about my 2004 G35X.
1. My driver seat belt is bit loose and most of the times it doesn’t go back to its position when I remove the seat belt. I need to manually take it to top and see if its fit in the idle position.
What can be done to tighten it?
2. My heated seat buttons on both sides (driver and passenger) do not light up when turned on. I mean the light inside it fused or what, I don’t know. But both the seats work well. Any suggestions to turn the lights on?
3. Also, I have driven a 2008 G35X and I felt its steering was very smooth as compared to mine. Does all 2004 G35X have a kinda rough steering?
4. I have a built in Infiniti GPS and wish to update its map. Any pointers for a cheap/reasonable update?
5. I had my gas tank cap torn off and bought a new one from Walmart for $8. Is it ok to continue with it or I need to go for a brand new Infiniti gas tank cap?
Any help is appreciated.
Thanks.
Old Apr 15, 2012 | 04:17 PM
danerikcom's Avatar
On the steering part I have a 04 G35X and the steering wheel is harder to turn then most other cars.
Old Apr 15, 2012 | 05:23 PM
BAUSauto's Avatar
Cap as in the thing you turn and goes click click click.. No you do not need an OEM one anything that will seal and hold pressure works
GPS map use to be downloadable like you can torrant it.. I did it with mines to get the latest update.. lol If not then just find somone with it and burn it or see if someone can burn the CD for you. I'm not sure if you'll still be able to find a downloadable map via torrant since our cars arent as popular as before.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
