whinning noise after parking at night
Old May 16, 2012 | 05:09 PM
morningla's Avatar
I have been have this whining noise coming for the engine bay for a while now.
It only occurs under these circumstances,
when i have parked the car for more than a few hours.
and only when i start to drive away from park (doesn't matter if it's high or low RPM).
the noise only happens once per drive and doesn't last more than a few seconds.
sounds like gears spinning.
my car is automatic.
wondering if anyone have heard similar sounds and figured out the issue, thanks.
Old May 17, 2012 | 12:11 AM
bmacchi14's Avatar
Is it a whine or a high pitched squeak for a couple seconds? If it's the squeak, it might be that your belts need adjusting. This was happening to me when I parked outside in the cold overnight. Upon start up in the morning, I'd get this high pitched squeak that lasted for a second or two then never happened the rest of the day as my G's engine got warm. I have an '06 sedan automatic.
Old May 17, 2012 | 06:19 AM
Caracicatriz's Avatar
It's most likely the ABS(?) doing a self check. I think it comes on at 9mph. Try hitting the brakes at that time and the sound should get worse. This is normal to our cars.
Old May 22, 2012 | 10:51 AM
morningla's Avatar
I went to listen to the sound more carefully a few time and it does sound like the ABS! thanks
Old May 22, 2012 | 09:00 PM
Mrpatar's Avatar
Ya my car does the same thing I'm glad it's all ok
Old May 23, 2012 | 06:39 AM
Blue Dream's Avatar
I drove ttrank's car solo
This is the correct answer.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
KallDay86
Jan 8, 2016 12:42 AM
dcsbh1
Oct 1, 2015 03:15 PM
