How do I remove driver seat? I need to redo a weld that broke.
Old Jul 5, 2012 | 08:33 AM
DVG's Avatar
DVG
Hi, I am looking for some help removing the driver seat on a 2003 sedan.
I have attempted to take off the bolts that connect it to the rails, but there is 1 that I can not get to, it is 2nd from the front and on the right. There is a bunch of motors and mechanical stuff in the way.
IF I did manage to get it off, I dont know how I would get it back on.
I need to remove the seat to redo a weld FYI
Anyone have any advice?
Am I doinitwrong?
Old Jul 5, 2012 | 12:57 PM
04G35NYC's Avatar
The seat is held only by 4 bolts, if thats the only bolt that preventing you from get it out then you will have to get it off some how.
Old Jul 5, 2012 | 01:34 PM
DVG's Avatar
DVG
I didnt know it was only held on by 4 bolts, I was trying to remove 8 bolts (Holds it to the rail)
I wasnt able to find any other bolts. Would you be able to point me in a direction of where to look?
Thanks
Old Jul 5, 2012 | 01:49 PM
04G35NYC's Avatar
Are you having problems getting the Seat out of the car its self, or getting the seat out of the rails them-self's?
Old Jul 5, 2012 | 02:06 PM
DVG's Avatar
DVG
Im having trouble getting the seat off of the rails right now, any tricks to get it out of the car would be helpful too, once I get it off the rails.
Old Jul 5, 2012 | 02:20 PM
Philly_G35's Avatar
Leave the rails attached to the seat, take off the four bolts that bolt the seat to the floor. Tip the seat back and undo all of the plugs, then just lift the seat out. I would unplug the negative terminal of the battery just to be safe.
Old Jul 5, 2012 | 03:19 PM
DVG's Avatar
DVG
Can you give me an idea of where those bolts are? Are they underneath the carpet or something?
Old Jul 5, 2012 | 03:34 PM
Philly_G35's Avatar
There are plastic covers over the bolts that pry up with a flat head screwdriver. They are at the front and back of the rails.
slider_ua
Jul 29, 2015 04:17 PM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
brian_z
Jul 20, 2015 01:30 AM
