2006 gauge cluster not working
Old Jul 18, 2012 | 06:19 PM
artsVQ's Avatar
hello
i was installing a new indash tv/radio when 2 hot wires touched after i was done installing i try to start the car and notice the dash light did not come on
i have checked all 2 fuse box's ,relays and dimmer switch
my gauge cluster don't light up when the car is on also the revs are slow when i push the gas pedal
the turn signal light and high beam light turn on in the cluster everything else is working good
here is a picture of the cluster with the car on and lights on
airbag light is on because i have not took my car in for the recall yet
TPS light is on because one tire is low on air
Uploaded with ImageShack.us
Old Jul 18, 2012 | 07:15 PM
TunerMax's Avatar
G35
How did you check the fuses?
The chances this is a fuse that you simply mised are very high.
Also I hope you learnt your lesson about working on electonics in your car with the battery connected
Old Jul 18, 2012 | 07:30 PM
artsVQ's Avatar
hey tuner
ill check the fuse box's again i was in a hurry when i 1st checked them
i ****ed up this time haha i was in a hurry to install the indash and did disconnect the battery =(
Old Jul 18, 2012 | 07:52 PM
neo_anderson302's Avatar
I never disconnect the battery, but I need to start too. Already been through 3 fuses in two months.
Old Jul 18, 2012 | 09:10 PM
artsVQ's Avatar
ok i fixed the problem it was a fuse i skipped =D
lol yeah its always good to disconnect the battery
Old Jul 19, 2012 | 06:55 AM
TunerMax's Avatar
G35
Old Jul 4, 2021 | 11:50 AM
2006VQDE's Avatar
infiniti G35 sedan
Originally Posted by TunerMax
which fuse had popped that you didn’t notice? I am having the same problem with my G and dash after I was messing with my radio.
Old Jul 4, 2021 | 11:51 AM
2006VQDE's Avatar
infiniti G35 sedan
Old Aug 25, 2021 | 09:48 AM
spykegtp's Avatar
g35
did you ever find out??
nickmcc123
Lights
Oct 7, 2017 12:18 AM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Th611
Oct 27, 2015 03:48 PM
.cakestar
Aug 4, 2015 09:05 PM
TWASkyliner
Aug 1, 2015 11:43 AM
