popping/clicking sound at slow speed?
Old Aug 14, 2012 | 08:54 AM
tahoe's Avatar
I have tried to search through this site but I havent really found what Im experiencing. At low speed when applying the brakes, like in stop and go traffic, I hearing a popping or clicking sound. It sounds like its coming from the front mostly but I think it could be coming from the rear too. Has anyone else experienced this or know what it is?
Old Aug 14, 2012 | 09:23 AM
mpugeda's Avatar
a video would help
Old Aug 14, 2012 | 01:27 PM
Subiedrewbie's Avatar
Video would be good like he said. You go through and tighten all the bolts to torque spec? Suspension and brake components
Old Aug 14, 2012 | 01:46 PM
tahoe's Avatar
a video might be tough but ill try...
Old Aug 14, 2012 | 01:54 PM
Mustang5L5's Avatar
Rear Axle Click?
There's a TSB
Old Aug 14, 2012 | 02:04 PM
tahoe's Avatar
i only hear it when i step on the brake in stop and go traffic, i dont hear it at higher speeds or over bumps
Old Aug 15, 2012 | 10:02 AM
Mustang5L5's Avatar
Sounds like "rear axle click"
Search those terms and you'll find out more info
Old Aug 15, 2012 | 10:21 AM
NjMatteSedan's Avatar
I'm having the same issue, happens when I brake or turn at low speed
Old Aug 15, 2012 | 11:14 AM
tahoe's Avatar
ive heard videos of the rear axle click and it doesnt sound like that and its not while excellerating, i only hear while applying the brakes at lower speed. it sounds like creaking/popping/clicking its hard to explain, i will try to get a video on my drive home today. i also have a front wheel bearing going bad but i dont think thats it?
Old Aug 15, 2012 | 02:44 PM
Mustang5L5's Avatar
Grab your brake calipers and shake them, do you have any play? Are all the shims present?
Old Aug 15, 2012 | 02:46 PM
tahoe's Avatar
i will take a look
Old Aug 15, 2012 | 04:17 PM
Mike04x's Avatar
I have pretty much the same problem, it might very well the the brake hardware I re-greased the the slides and calipers and i still have the same sounds
Old Apr 27, 2013 | 01:42 AM
Ramiel's Avatar
Sorry to necropost, but yeah I'm having a similar experience. It's not rear axel click, I already took care of that one, this one comes in when I gently apply the brakes at low speed. its a rythemic click in time with the rotation of the wheels. It also clicks when I step on the brake pedal. Might check the calipers for play and pads for wear. The shims thing mentioned seems like a possibility.
OP, did you end up resolving the issue?
dorkstar
Steering & Suspension
Sep 16, 2015 01:02 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Terry_G35
Sep 10, 2015 08:17 PM
