VDC light always on
Old Aug 16, 2012 | 07:16 PM
newG's Avatar
VDC light always on
Hey guys, first post here, I've been cruising this site for the past month and have found a good amount of info about my G35 that I recently purchased but I'm still having an issue with my VDC. I have an 04 g35 sedan and my VDC off light is constantly on, it never goes away. The light has been on since I bought the car. The car pulled to the right so I took it to the shop for an alignment and was told my bushing were shot in my front lower control arms and upper right control arm so I replaced all of the lower control arms and upper right arm.
I took the G back in for an alignment(thinking this would make my VDC light turn off) they did the alignment but said that my camber was off on the front left. I then replaced the front left upper arm. Well my car still pulls to the right and the VDC off light is still on.
What do I do now? Do I need to take it back in for an alignment? Is my frame bent? I'm thoroughly stumped with this. Any help is greatly appreciated
Old Aug 16, 2012 | 08:53 PM
sonicii's Avatar
The 'VDC off' light won't be due to an alignment or suspension fault, you should get the codes read to check what is causing this.
Take the car back to the shop that did the alignment and tell them it is still pulling to the right and ask them to find out why.. after all, this is what they do!.
Old Aug 16, 2012 | 08:59 PM
Michael Jay's Avatar
I'm having the exact same issue. If I come upon a resolution I will post asap.
Luisgalvan33
Jul 19, 2018 08:16 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
MsFitFern
Aug 9, 2015 02:58 PM
