NEED HELP!!!! rear window defroster, drl, memory seat and trunk light not working
Subscribei have a 03 sedan and all these things stop working in the past week need help finding the problem
so many views no one knows
again my trunk light doesnt work all the other lights work
the driver seat only works when i turn the key to on position but the passanger seat dont not
it works without turning the key the buttons on the side 1 and 2 doesnt light
my day time running light dont work but high beams work fine
the defroster botton when press it doesnt even light so cant defrost my back glass (canada)
everything else works fine
anyone
anyone
I had a sort of similar issues. Lots of random systems going down. There was a fray in the wiring to the reverse lights which was shorting out other systems.
I also had an alternator dying which apparently was sending too much juice through the system, which also might have been the problem.
That said when I brought the car home it threw the brake/battery lights again so I might still be looking for the culprit. Hope my follies have helped - will update when I get rid of the damned lights.
Every time something happens that affects the trunk I recommend checking your trunk wiring. It is most likely frayed anyways.
[QUOTE=billb300;6698125]Have you checked the fuses?[/
If u could tell which fuse to look at I can check them out
