NewB fitment question
Old Oct 26, 2012 | 06:11 AM
4drSS_V35's Avatar
im ready to get flamed on this but I just wanted to know if its possible to run 9.5 front and 10.5 rear +12 all around with stock camber. meaning no camber kit whatsoever but im pretty slammed and had a alignment to get my toe back into stock specs. so im pretty much running -3 front and -4.2 in the rear. just wondering if i still can run the wheel fitment stated above. i also know that i have to pull and flare the fenders wich im ready for . just wondering if i can pull it off though. all comments are welcomed and pix too pls.
Old Oct 26, 2012 | 06:12 AM
4drSS_V35's Avatar
will also be running stretched tires. 225/35 front and 245/35 rear, maybe a 235/35.
Old Oct 26, 2012 | 01:54 PM
VMRWheels's Avatar
That fitment is fairly aggressive for your car... Just depends on how much fender work you're going to be doing and what tire you plan on running.
Old Oct 26, 2012 | 02:08 PM
gtrefever's Avatar
You'll be good. A slight pull in the rear, maybe.
Old Oct 26, 2012 | 06:08 PM
4drSS_V35's Avatar
thanks guys. i know for sure that the rears gotta be pulled a flared a bit and the fronts need a roll but just wondering if i can pull it off with the camber im already running. pix and more opinions would also help .
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
