Stock passenger side HID Low Beam not working Help!!
Old Nov 15, 2012 | 11:54 AM
Threepoint5's Avatar
So my Passenger side Beam isnt working, I checked the fuse box inside the car and also behind the battery and everything seems fine. The only thing that remains is replacing the ballast. Can I just get a stock replacement for just one side? or Am i forced to go with Aftermarket HIDs?
Old Nov 15, 2012 | 02:48 PM
saywat?'s Avatar
check the marketplace.
Old Nov 15, 2012 | 06:08 PM
Mustang5L5's Avatar
Did you check the bulb first? Why go straight for the ballast when it's more than likely the bulb has failed.
Swap the bulbs to opposite sides and see if the problem follows the swap. If so...dead bulb
Old Nov 16, 2012 | 11:23 AM
01yellowr's Avatar
Check the bulb first. It would suck to buy a ballast when all you need is a bulb. If it is the ballast let me know I think I have an extra
Old Nov 16, 2012 | 12:07 PM
I did check the bulb, because that was my first thought so i went ahead and ordered a new set and still no light. Thats when i checked the fuses and they were good, so im guessing the only thing left to go bad would be a ballast
Old Nov 17, 2012 | 12:52 PM
Chucks 04's Avatar
I'm having the same prob with my driver side I hadn't checked it out yet but you can check eBay there are some ballast box on there
Jusseth
Sep 13, 2020 12:25 PM
mbe093
Lights
Oct 2, 2016 11:09 PM
R350k5
Oct 1, 2015 08:41 PM
wylin
Lights
Jul 18, 2015 06:12 PM
