Key Transponder Chip Programming (lost key code)
Old Dec 9, 2012 | 12:57 AM
Tolboothwilley™'s Avatar
I went to get my key programmed from a locksmith (cut/program) but when they hooked up their machine it would not register the ECU.
I used to have a little metal tag with a 4 digit pin code for programming the key. It was on the key ring that was lost and I am replacing.
My questions:
Is it possible to recover the key code? is the key code specific to my vehicle?
Trying to avoid going to the stealership - they want to charge $125 JUST TO PROGRAM. Greedy b@st@rds.
The real issue is because i have an early 2003 with the diff ECU - all the other ECUs work from the locksmiths experience.
Old Dec 9, 2012 | 02:54 AM
g35SedanSC's Avatar
125 sounds decent,its 245 for me.
Old Dec 9, 2012 | 01:14 PM
falcor's Avatar
it's possible.. shoot me a pm and we can talk about it
Old Dec 9, 2012 | 01:41 PM
KrazySouthG35's Avatar
I'd also like to know if there's any way to program a key myself I have an extra blank
Old Dec 9, 2012 | 10:45 PM
Wow, thats insanse. The locksmith cut my key for free for me. The programming takes all of 5 min
PM sent buddy
I don't think you can program it yourself - some cars can but not ours (as far as i know)
all keys must be programmed at the same time - when you program them you delete previous codes and only program the ones you have
I'm told some companies are able to "clone" the signal though
Old Dec 10, 2012 | 08:49 AM
Adro's Avatar
Yikes, the dealer cut and programmed 2 keys for me $60 total. Your dealer is trying to get one over on you.
Old Dec 10, 2012 | 11:52 AM
i called 4 different dealers (Nissan/Infiniti) here in Vegas and they ranged from $110-145
Other dealers elsewhere charge like $45...I'm gonna have it programmed when I head out of town for the holidays
Old Sep 2, 2021 | 01:32 PM
Aikiden's Avatar
Early 2003 Sport Tuned Suspension white with sunroof
I've also got a 2003 that the ACE HW was unable to program and have no metal tag with code. Suggestions?
Old Sep 2, 2021 | 09:24 PM
MooseLucifer's Avatar
5 Year Member
blk
9yo thread, but check around with locksmiths. My guy still charges $125ish if I remember correctly.
Old Sep 4, 2021 | 11:09 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That pin code is just the decoded BCM pin. You can use an online BCM decoder to get the pin number.
Look on the front of the BCM, there's a 5 digit alphanumeric code, it literally says PIN: ##### you need that code, put it into a BCM decoder online, it returns the 4 digit actual pin number you need for the BCM.
It's was part of the component anti-theft system and it was pretty effective since the only way to get the pin USED TO BE using the Nissan software. Now however those decoders are available online so I just wrote the pin number for mine in sharpie right on the BCM so I don't need to look it up every time.
Here's the site I used, I know it asks for a 20 digit code but just putting in the 5 digit code from your BCM works.
http://keytechtools.com/bcmcodes/index.php
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Detailed Image
Jul 24, 2015 12:31 PM
Detailed Image
Jul 21, 2015 08:50 AM
