Newbie here...headlight question
Old Jan 13, 2013 | 07:56 PM
sckandalus18's Avatar
I have a 2005 g35x. I wanted to change the headlights on my car. I was going to just change the bulb but then i saw that the shades were dull. I figured I should just change the whole thing. I dont know if it just that the headlights are dull but I cannot see when I drive at night.
My question.. What is a good headlight to change it to? Should I buy a HID kit? I dont know what I need. I just need brighter lights.
Thanks for the help in advance!!
Old Jan 13, 2013 | 08:20 PM
5150DS's Avatar
You have hids from the factory. Stand in front of your car with the headlights on to see if a bulb is out. If not you can use a headlights cleaning kit to clear the lenses. One new headlights for this car is over $300.
jcseven7's Avatar
Sweet sweet headlights...
Old Jan 14, 2013 | 07:37 AM
Mustang5L5's Avatar
Your headlights are already HID. They use a bulb type called a D2R
Not sure what you mean by the "shades" are dull.
HID bulbs do become dimmer as they age. If your bulbs are original, they are 8 years old.
Grab a pair of aftermarket 5000-6000K D2R bulbs from an online vendor (don't go 8K as the human eye has trouble seeing light once you get higher than 5000K) and a tube of PlastX from Autozone. The PlastX can do a decent job of polishing thbe lights. Once done, apply a few coats of wax to the lens and repeat every 3 months or so.
Old Jan 17, 2013 | 09:38 PM
Mosheh1am's Avatar
Originally Posted by jcseven7
That was hilarious, i was stitched up for a good min.
On topic: you could buy aftermarket lights for cheep on ebay, like everything though you get what you par for. I would have a detail-er wet-sand your headlights and you could spray on a UV protection film and you'll be good.
Old Jan 18, 2013 | 09:19 AM
ristau5741's Avatar
toothpaste is another solution to the cloudy light covers, apply, rub, wash off. and should clean them in no time. just don't get toothpaste on paint as it will damage the paint.
Old Jan 18, 2013 | 12:52 PM
Mustang5L5's Avatar
Chocolate works well as a polish too.
Plus you can eat it!
Old Jan 18, 2013 | 01:00 PM
Tolboothwilley™'s Avatar
lol, its from the grit....
just get the 3M headlight restoration kit
If you are ambition put some Morimoto Mini projectors in the tops, or you could do bottoms at the same time
Get the morimoto bulbs if you are replacing them
http://www.theretrofitsource.com/ << Great place for buying projectors/bulbs/etc
Use the 3M Headlight Restoration Kit to clean the lens and UV protect them afterward
follow this thread: http://my350z.com/forum/body-interio...v-coating.html
Old Jan 18, 2013 | 01:30 PM
gary c's Avatar
TBWs recommendation is perfect, no one makes a better headlight restoration kit than 3M....nobody!
Gary
Old Jan 18, 2013 | 01:32 PM
5150DS's Avatar
Just not gel ; v )
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
