A/C Console Not Working
Old Apr 11, 2013 | 09:25 AM
JRandallC's Avatar
2003 G35
Occasionally the A/C console will stop working. The first time it happened, I removed the radio/AC controls from the dash, poked around a bit, pulled the power on that whole unit and put everything back together without really fixing anything and it worked again. A few months later, the A/C console stopped working again, and I ran through the routine again. And I've done that one more time. My question now is, is there some sweet spot anyone is aware of that may be causing this behavior? Obviously I'm setting something right when I take the console out and put it back, but it's not a permanent fix. The console will usually go out again if the dash gets bumped or if a door is closed too hard. Some sort of jarring behavior like that.
To be more specific on the symptoms, I can see the status of the A/C unit (temp, fan speed, etc), but none of the controls will work to change the settings, and the A/C just doesn't blow. Also, the radio doesn't work from the console controls, but it will work from the steering wheel controls.
Old Apr 11, 2013 | 11:41 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by JRandallC
2003 G35
Radio and A/C share their power circuit for the display, so when it goes, bad things happen. Your best option now is to start saving for a replacement radio so you won't have to deal with this down the road.
The list of parts you need and instructions on how to do it can be found the the a/v forums - https://g35driver.com/forums/audio-v...urce-list.html
champppy
Mar 31, 2020 12:25 PM
Gip
Aug 24, 2015 05:31 PM
Rehman2009
Jul 27, 2015 03:23 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
