Code P1283 questions
Old May 15, 2013 | 06:13 PM
ristau5741's Avatar
I put in a can of BG 44K in my fuel tanks about a month ago,
ever since whenever I accelerate quickly, e.g. merging onto the highway
I get a P1283 code, This has happened 3 times since the 44K was put in.
If I drive like an old man for ~200-250 miles the warning clears.
Also I get 7 MIL codes
Misfire
Fuel
Comp
Catalyst
EVAP
02 SNSR
02 HTR
any ideas???
the P1283 is a lean warning, I figure that it was caused by the 44K. I figured I'd ask for others experience.
Old May 15, 2013 | 06:25 PM
cvipgo's Avatar
first clean your Air Flow Meter- could be Faulty Air Flow Meter.
Old May 16, 2013 | 06:41 AM
srv2nv's Avatar
G35 Sport
How many miles are on your car? I'm wondering if the 44K loosened some gunk up inside the tank and its clogged the fuel filter...I've heard of it happening on higher mileage vehicles.
Old May 16, 2013 | 09:24 AM
LoSt180's Avatar
P1283 is related to the driver's side O2 sensor. Sounds like you're getting more than just that code though.
Possible causes are:
- Air fuel ratio (A/F) sensor 1
- Air fuel ratio (A/F) sensor 1 heater
- Fuel pressure
- Fuel injector
- Intake air leaks
Old May 16, 2013 | 10:51 AM
ristau5741's Avatar
Coming up on 120K
Hasanbaloch
Feb 29, 2024 08:45 PM
Muski_G
Dec 1, 2023 11:11 AM
Detailed Image
Aug 17, 2015 02:45 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Detailed Image
Jul 29, 2015 08:42 AM
