jamming cd's
Old Jan 30, 2005 | 09:10 PM
jadaway2's Avatar
jamming cd's
anyone ever heard of a problem with the cd's jamming in the disc changer on the 03 radio? mine are stuck right now and it's making a clicking noise everytime i start the car.
Old Jan 31, 2005 | 07:54 AM
skeleton_cru's Avatar
Sedan
Known issue with the '03. Do a search.
Old Jan 31, 2005 | 08:49 AM
scarrabblue's Avatar
This happened to me a year, or so ago. If you have burned CD's, with lables that you attached, they can heat up, causing the label to jam the unit. The only way to fix it is to make an appt. with your dealer, so that they can order a new head unit. They normally do not have these in stock, so you may be without your CD player for a few weeks. Mine was covered under warranty.
Good luck!
Old Jan 31, 2005 | 10:31 AM
Augy's Avatar
I had the same problem last week. I had a cd error message display. The dealer replaced the head unit. It works fine now.
Old Jan 31, 2005 | 01:50 PM
smcginnis87's Avatar
well i got a 03 and i dont have that prob sorry man...
Old Jan 31, 2005 | 02:53 PM
GeoBau's Avatar
Cactus Hugging Admin
It actually can happen with just about any CD, with any label. The film labels definitely help the problem along, though. Sometimes if you press 1-2-4-2-3, etc. it will jam. I plan on purposefully jamming mine right before 30,000 just so I can dodge that bullet.
G
Old Jan 31, 2005 | 03:01 PM
fullofivy's Avatar
Just a word of caution FWIW - - a friend has a Pathfinder. His CD changer got jammed and the dealer made him pay for the replacement. The dealer said his use of bootleg CD caused the problem! It is not a definite warranty item but probably more of case by case.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Th611
Oct 27, 2015 03:48 PM
Frostbite91
Aug 20, 2015 07:20 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
